Question about SanDisk Sansa e260 MP3 Player
Re: Wont download
I always try to load songs onto my Sansa but when I disconnect it and i press play all, it says there are no songs in my sansa!
  • 1 more comment
  • firefishy
    firefishy Apr 13, 2008
    that was by me but my grandpa helpped me
  • firefishy
    I fixed it. I just needed Windows player 10.
  • Anonymous May 14, 2008
    when i put songs on it the sonds don't show up
I acctually had wmp 9 but i needed wmp 10
Posted on Apr 20, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Cant load songs
hi sir
please try to re-install and try.
if it not then go to the tools >setting>phone>restore factory setting.. and type ur passward. i think it will work.. don't forget to fix
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 computer problems
Try using Windows Media Player instead, and see if you get the same result. If it loads in Windows Media Player, then the problem is with WinAmp and not your Mp3 player. When you say it loads half-way, do you mean it loads half the songs and then shuts off? Is the Sansa running on low battery? WinAmp has some kind of update released in the past week - did you download the update, and then experience the problem? It's probably not this, because other users have had the same problem that you are reporting since at least Christmas 2007.
The following is an advice from another Sansa user, so I haven't been able to verify it myself:
"I have to have WinAmp open and a song playing then connect my player and then it will work fine. If I just connect my player then start WinAmp it crashes"
If all of the above fails, reformat your player and start over from scratch. Let me know how everything works out - this is an issue that not even the Sansa website seems to have an answer for.
-Tha Mp3 Doctor
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Wont put songs on
I would wait for the writing message to go away before disconnecting the player - this is the standard message it will give you when you are transferring songs to the player. If it still says writing after 5 minutes (this is assuming you are not trying to load more than 20 songs at once), then you might have a real problem.
Make sure the files you are trying to load do not have DRM encryption on them, and also make sure they are in mp3 or wma format.
If you have Windows Media Player 11:
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 16, 2008 | SanDisk Sansa E280 MP3 Player
My sansa m250 help
click refresh on your windows media player!!
Dec 27, 2007 | SanDisk Sansa m240 MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
My Sansa skips the songs I put on it, what can should I do
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
-Raj
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
