Question about Casio EXILIM Card EX-S770 Digital Camera
Won't turn on
I have had my camera for only 4 months, and it has hardly been used. It won't turn on, so i have had it sat it the pod all day, and it still won't turn on. The red light on the pod is constantly flashing too and not going green to say it is charged.
What do you think the problem is?
Thank you
Steph
  • 2 more comments
  • Anonymous Apr 13, 2008
    camera is charging red and will not go green and will not turn on.
  • Arreis Eroom Apr 18, 2008
    my camera will not charge. it has a red blinking light and never goes green. if i press the 'Photo' button the slideshow works but nothing charges and it will not turn on whatsoever. could it be the battery is completly dead and will not even charge or what?
  • Eliz13 May 01, 2008
    I just ran across the same problem. The light on the charging pod stays green and I can view the slide show when it is on the pod but I can not turn the camera on. Maybe the problem is with the battery.
  • ginsengyo May 04, 2008
    sooo i guess we all have the same problem. lets mourn together
Wow, me too I have the same problem and I can also view the slides! Except I know that it's not the battery for a fact because I went through the whole hassle of buying new batteries and a new charger where you plug directly into the wall and it still doesn't work. I guess no one has a solution... What a horrible defect. And it started not working when I turned on the camera and the lens came out, but I right away it broke down. And it took a while before I figured out how to shut the camera off to get the lens back inside.
Posted on May 06, 2008
  • AliceC May 06, 2008
    Woops, sorry guys, I didn't know how to post a comment so I posted in the solution section instead.
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Hard start back fires in the front won't go more then 10 mph
Did you change the fuel filter, and have you checked fuel pressure with a gauge ?
Apr 08, 2013 | 1992 Chrysler New Yorker
'07 klr 650 won't run without choke on
Hi, Lance and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Won run without choke
KLR won idle without choke backfires on decel
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
Kawasaki KLR650 Owner Manual
Jul 01, 2017 | 2007 kawasaki KLR 650
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
Drive used from march 11 to april 20 no problem. sat for two weeks unused, computer also unused, neither turned on. drive won't mount via FW 800 so i have been using USB 2 for two days, now it...
It sounds like the controller board or the electronics in your WD enclosure have gone bad or gotten fried somehow. The good news is that more than likely all your information is still there. I would try to crack open the outer plastic casing and physically remove the drive. Then purchase an adapter from Amazon (like this one)
May 05, 2011 | Western Digital 2TB My Book Studio II Hard...
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
78 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
