Question about Sony Handycam DCR-HC14E Mini DV Digital Camcorder
SOUND WHEN PLAYING BACK THE FILM I HAVE JUST TAKEN SOUND COME AND GOES IF YOU PUT THE SAME TAPE IN ANOTHER CAMRECORDER IT STILL DOES IT BUT IF YOU PLAY A TAPE FROM ANOTHER CAMRECORDER IT PLAYS FINE IS IT THE MIC THAT IS CAUSEING THIS
Sounds like a bad tape,have you tried recording on the other cams tape !
Posted on Jun 07, 2008
Tip
I've been unable to play several bought VHS tapes of films, though oddly,...
Vcr's commonly get dirty heads that cause a blue or snowy screen and no sound in some cases. In my experience the rental tapes were common point of trouble especially when you consider the amount of machines that were deployed in use back in those days. Today people run into less issues because they have there own collection and put them to good use. In order to deal with some people's problems there are three approaches to cleaning heads, the first option is to use a wet tape with the provided fluid usually two or three drops will do and run it for ten to twenty seconds. The second approach is use a dry tape with same amount of time as outlined above. The third approach is get a blank store bought tape "T120 2hours" set the vcr to sp and run the tape from beginning to end, this is a good way if you want do more of a deep clean to remove difficult dirty particles that refuse give way. I find the dry tape will give less problems when cleaning and less chance of shredding and easier for people who don't like taking vcr's apart.
on Jun 02, 2011 | Televison & Video
Won't print tape jam Have taken the tape out and put back in also
For me, a bunch of the tape somehow got stuck in the roller... I had to use a tweezer to pull it all out.
Aug 24, 2009 | Dymo LetraTAG Thermal Label Printer
Dcr-trv320e
Hi 8 tapes will only play on a Hi 8 machine. I would recommend you search for a place that will do the video transfer for you. There are several in my town and likely you could find one on the internet.
Oct 18, 2008 | Video Cameras
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no...
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Jul 24, 2008 | Cameras
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
R 0:00 -- can't play back tape
try to clean the video head...i advise to use a blank tape and fastforward it until the time code counter display...you should on it the menu of the camera..
Aug 05, 2007 | Panasonic PV-GS500 Camcorder
Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Jan 22, 2007 | Philips VR540 VHS VCR
Sony Handycam DCR-HC14E Mini DV Digital Camcorder Logo
66 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
