Question about Pioneer Audio Players & Recorders
Pioneer vsz 517 reciever powerd off wont come on
  • 4 Answers
I have a VSX Pioneer. Somewhere either in the back of the rfeceiver or one of the speakers there is an errant wire touching the frame. Check the back of the receiver ald all of the speaker connections. The message is to protect the speaker, but can tke out a channel on the receiver if not corrected.
Posted on Jun 12, 2008
Jvm error 517 on blackberry 9300
hp blackberry 9300 jvm eror 517,mita solusinya boss...ni hp udah saya instal lebih dari 5X.hasil ttep ....
Jun 02, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
Im receiving a jvm error 517?
You need to reload the operating system back onto the device. check out blackberry.com to download the software you need under help and support
Apr 04, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Nov 03, 2009 | Pioneer VSX-517
New pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
May 25, 2009 | Pioneer VSX-517
Overload on home theatre reciever
It would mean one of the power modules died. I believe they are STK412-530. Not an easy repair for a DIY.
Good luck
May 23, 2009 | JBL PP-600II System
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
That model does not support audio via hdmi. That is the problem.
Jan 04, 2009 | Pioneer VSX-818V-K Receiver
OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Jan 02, 2009 | Pioneer Audio Players & Recorders
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
210 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
