Phillips 60pw9363 Which IC is red and which is blue
One day while watching t.v. (Phillips 60pw9363) my son said the t.v. made a loud popping noise and the picture went bad. I did a bit of online research and narrowed the problem down to probably being the ic chips (stk392-180). I replaced both and could now align the red but the blue convergence still doesn't move. How can I tell which is which? I would like to just replace the blue ic chip but there doesn't seem to be any indication on the board to tell them apart. Am I on the right track here or am I totally off track? Any helpful suggestions would be greatly appreciated.
Kind Regards,
Philip
  • WIbrewer Apr 13, 2008
    Hi Slinteriors,
    Thanks for the help. It is much appreciated. I took out the board and looked around the IC chips for a discolored resistor. None of them look discolored and I couldn't find any one with 6R8 ohm 1WJ on it. I have taken pictures of the area around the two IC chips. Do you have an email I could send them to? Maybe you could specify which ones I should look at.
    Kind Regards,
    Philip
  • EggbertsMom
    EggbertsMom Sep 28, 2008
    Same TV here - no popping noise but I have a sideways hourglass with some color distortion. Husband was able to adjust the red convergence to fix the color but we still have a black hourglass distortion. Can you help?
  • 8,617 Answers
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Posted on Apr 12, 2008
  • Sonny Berry
    Sonny Berry Apr 13, 2008
    yes send it to slinteriors@yahoo.com
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
My red convergence won't move side to side only up and down what do i do? the blue moves up down and side to side, i noticed this when the picture as we were watching it decided to turn 3d, so i tried to...
Most of these Philips sets use two STK-392-120 convergence IC chips; if you can locate them inside look at all the little blue resistors to the left and front of them---these are feedback (protect) parts---if any of them are discolored in the middle--not powder blue but somewhat white in the middle---you have a bad ic and both need to be replaced---most of the protect resistors are 6.8 ohm in value. If this has been helpful give me a vote.
Aug 14, 2009 | Philips 60PW9363 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Sony kp41s3u - blue screen
Convergence amp ic bad or loose connection on ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Feb 26, 2008 | Televison & Video
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Red and blue lines on the buttom of the TV
i'm only 11, but i have the same problem. check the power cord.
Apr 09, 2007 | Philips 60PW9363 60" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
