Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Maytag won't cool
Can't get our refrigerator to cool below 66 degrees
  • Anonymous Jan 06, 2009
    Huh, replace the fan motor... This thing is only 2 years old. Bummer. I guess I'll try it out.
    Genius:
  • 1,073 Answers
Check to see if the freexer fan is runnig, if not replace the fan motor, i have changed a bunch of these fan motors
Posted on Apr 12, 2008
My unit is not cooling properly and ice is forming on back wall
You are low on refrigerant and likely have a leak. Needs located and repaired and then recharged.
Jun 23, 2017 | Heating & Cooling
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Maytag Refirgerator Model MTB2156FE freezer not cooling below 32 degrees
HI PAUL.FREEZER NOT COOLING could be for many reasons.go through the basics first .1-check if your freezer is iced up 2 if yes defrost it all completely first .then turn on 3-if ok then your problem could be 4-defrost timer 5-defrost heater 6-t/stat.if not iced up then check /clean thoroughly the condenser unit 7-check con/fan 8-check condenser should be warm/hot.if cold and motor hot then it could be lack of refrigerant (internal leak?) hope this helps.ALI
Jun 30, 2012 | Refrigerators
Maytag Refrigerator MFI2568AES not cold enough. Hi! Our Refrigerator is working. The inside temp 66 and the Freezer is at 61 degrees. Any ideas? The replace filter light was on (it's time to...
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
And for ice maker problem
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks.Helpmech.
Oct 10, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator temperature won't cool items lower than 41 degrees.I assume this is caused by a faulty thermostat.It is a Maytag Plus model MTB2156AE.
Not necessarily the themostat. It could be the internal fan that circulates the air from freezer to fridge or you have ice blocking the air flow.
Sep 13, 2011 | Maytag Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Beer is not chilling and the display keeps blinking
Let me know what you find out. I un plug the thermastate and it stops blinking. If I plug back in. It starts blinking again. Regardless with or with out it plugged in the unit will
not cool below 66 degree's. I think there isosomething wrong with
the cooling agent or the thermastat
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
Refrigerator isn't cooling below 58 degrees and freezer isn't cooling below 18 degrees. What is the problem? IS IT WORTH TRYING TO FIX IT?
Depending on age of unit. Sounds like a fan motor or defrost heaters witch can cost up to 300 to 400 to fix depending on the heaters or motor. Ask for free estimate before you commit to fix. Rus
Jun 27, 2009 | Maytag Dual Cool 29 cu. ft. Side-by-Side...
AIR CONDITIONER COMES ON BUT DOES NOT BLOW COOL AIR
It is possible that your unit needs refrigerant but Before I would have someone recharge it they would have to locate the point of leak and repair it. I would check to make sure it is not some other problem first, like is the compressor operating.
Jun 15, 2008 | Maytag M6P09S2ACOM Air Conditioner
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
96 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
