Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Adjustments Sir, Can the convergence be adjusted without the original remote? Maybe a generic one bought at Wal-mart. If so, please advise. Thanks so much, Les lesfurrow@yahoo.com
  • 53 Answers
On the Akai PT429HD? No, you need the original Samsung, as only it has the button to save convergence settings. I got mine for ten bucks. Without doing a proper convergence your set is kind of wasted, so that ten bucks is worth it. I see the price of this remote has spiked lately, so I'd start with ebay first of all.
If you've tried my convergence procedure on the Akai remote and can find a button that saves the settings (the cursor will blink and then center) then you don't need to buy a Samsung one. The only universal remote that has a chance of doing the job would be more expensive than the real one.
Posted on Apr 12, 2008
Color adjust without original remote cs-35303
Almost any Mitsubishi remote will work for standard adjustments--just that simple.
If issue is too much red, green or blue(not a good black and white picture) the controls for those adjustments are located inside the set on the board that plugs onto the end of the picture tube.
Let me know what your issue is and I will advise further.
Mar 20, 2012 | Televison & Video
I bought a schwinn 26"
Take it back to wal-mart and get a new bike. They will return the defective one. If you have a receipt it should be no problem, probably will not be a problem even without a receipt as long as you are just exchanging it.
Jul 23, 2011 | Cycling
Can't change display or audio settings "block" symbol...
they did if you have the manual it will walk you through how to switch from store floor model to home useage
Jul 01, 2010 | Sharp LC46SB54U 46 in. LCD TV
Need manual for 6qt GE SLOW COOKER, #169200
You can download the manual from GE's site here. Hope this helps you, and thanks for using Fixya!
Jan 09, 2010 | GE Crock Pots & Slow Cookers
I just replaced convergence chips on my 51 inch magnavox and it looks good, but i have to keep adjusting it every time i turn it on.
If you are adjusting the convergence in the customer menu you will have this problem.
What is model number of the Magnavox and do you have the original remote working for it?
There is a TECH menu for adjusting the convergence all over the screen--part of this is when you adjust there--you hit a couple of buttons and it SAVES the adjustments into the set's memory.
If you have the original remote I can tell you how to enter this mode and save the adjustments---The customer mode will usually give ok results but the TECH should give lasting adjustments.
Let me know and I will tell you how to get in etc.
If this information helps you rate this solution as I do this here for free---I am here to help people.
SD TECH
Nov 05, 2009 | Toshiba 53H71 53 in. Rear Projection...
My convergence is fine but after professional replacement of the board there is a slight bowing and slanting of in-screen borders and some channels have a little distortion at the top of the screen. The...
First: If the convergence board was replaced--the set may need a total adjustment---this is why most good techs replace the convergence chips and any bad parts instead--also costs less----Second: to enter the service mode (it is done with the set already turned on) should be Mute, 182 or Mute 183---if you get the convergence mode--7,8, 9 will select red, green, blue, 5 will stop the cursor from blinking and allow adjustment---with the cursor blinking 2,8, 4, 6 will allow you to navigate---depending on the remote used--the P mode button will take you across the screen in a series of steps--the remote I use for this has a button on it marked data save--this saves the adjustments. Your remote may have it or a different button for this.
Understand---if you get into the convergence mode---Green determines if the geometry of the picture is straight---red and blue are adjusted to it---to align the green you need to call the convergence mode up and then cover the lens for the red and blue---leaves you with a green grid---then you need to select green and wherever the grid is not straight adjust it--once you get it straight you need to uncover the red and adjust it to the green, and then the blue to the green---green alignment determines if the picture is straight---It sounds like this guy did not try to get the green straight and just adjusted the red and blue to whatever the green was.
My point here is if you paid money for this repair--either he aligns it straight or you should get your money back----GREEN never needs to be adjusted unless the dcu(digital convergence unit that stores the adjustments) has been replaced or the Convergence module has been replaced---I bet if the original convergence module was repaired(chips replaced etc) and installed you would not have this problem.
If the guy replaced the DCU then GREEN must be fully adjusted for a straight picture FIRST! then red and blue adjusted to it.
It is not easy or quick to Adjust the green--maybe he just wanted to get out the door?
I do this here for free so if this has helped you take a minute and give me a vote here.
If you have any questions or need help reply to this post here.
SD TECH
Sep 05, 2009 | Samsung PCL6215R 62" Rear Projection...
Remote was damaged
The original remote has to be ordered and shipped from the manufacturer. as for a replacement, you can find one at your local wal mart.
Feb 01, 2009 | Quasar VV-2002 20 in. TV/VCR Combo
Registering 2 yr service plan for Wii
  • I AM TRYING TO REGISTER A2 YEAR PLAN FOR A WII STATION THAT PURCHASASED AT WAL MART. PLEASE ADVISE ME ON HOW TO TO DO THIS. THANK YOU.
Jan 22, 2009 | Microsoft Xbox 360 Console
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
