Question about Kitchen Ranges
Kitchen Aid KESH307BBL9 with a F2:E5 displayed code
I have replaced the control board (made sure everything is plugged back as they were on original). Most of the keys work fine. However, when I set the oven temp to any temperature, the "Start" key is unresponsive - same goes for the "Cancel" key. What else can be wrong? The keys for the "clock control" work fine.
    Genius:
  • 1,073 Answers
Clean the ribbion connector off with a pencel eraser a few times and reinsert into the control, if this does not solve the issue then you nedd tor replace the touch pad, which will come with a new ribbon
Posted on Apr 12, 2008
The code E5 F2 comes up on the control panel ,what dose that mean .
Hello Danny;
My name is Peter. I am a retired field service appliance technician.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
You have left the last number off your model number. If it is '0':
PART NUMBER: W10114377 Cost: $241.00
If you elect to replace the control board, make sure when you receive the new board in a anti-static gray bag, ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock out a board.
The price provided is from Sears Direct. You can get the same part on E-bay for $110.00.
Rule of Thumb: "If the cost of repair is 1/3 or greater than the original purchase price, then buy new."
You have a older but nice unit.
Peter Goodwin
Glen Burnie, MD
443-306-1362
Jan 15, 2015 | Whirlpool Accubake RF362LXTT Electric...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
A code pops up on my oven e5 f2 what dose that mean
Hello Danny;
Peter Goodwin
Glen Burnie, MD
443-306-1362
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
I have a Kitchen Aid Slide in Range model KESC300BBL8. When using the oven it keeps shutting off after a short time. F2-E5 will be displayed.
F2-E5 is "Cancel Key Drive Line Open"
Here is the procedure
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Thanks to: http://www.appliancepartspros.com Make sure to have your model number handy.. before calling a repair man or ordering parts.. Hopefully it's a lose connection.. Best of luck!
Apr 22, 2011 | KitchenAid Kitchen Ranges
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
I get an F2 E5 error on my panel, what is wrong? the bake does not work.
As per Manual :-
F2 E5 - Cancel key drive line open.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | KitchenAid KERA205P Electric Kitchen Range
Kitchenaid Oven won't work E0 F2 on the control pad
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Neff electric oven
I also have this problem. Replaced control board, but didn't help.
Display worked fine until control board was replaced. Now display is very hard to operate. It's no sensitive enough to touch. Displays F2:ES (or F2:E5) when cancel is pressed.
Jan 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
106 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
