Question about Danby DWC283BLS Wine Cooler
Danby Wine cooler runs and runs
My Danby Wine coller runs and runs but does not cycle off when the proper temp is reached. Thermostat? How do I check and repair? I"m curious if this is easy enough to accomplish. Thanks!
  • 1 more comment
  • Yerigan Apr 12, 2008
    How would I replace, where do I look on the unit? Any suggestions for where to find parts? Would this be the thermostat?
  • Anonymous May 01, 2008
    My compresssor will not shut off. Where is the thermostat for the lower part of the cooler?
    How do you replace it?
    My compressor will not stop running.
    Where is the thormostat for the lower part of the cooler? How do you replace it?
    Genius:
  • 1,073 Answers
Not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Posted on Apr 12, 2008
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Constantly running reving on and off but keeping temp
If it keeps the temperature, it appears to be working properly!
Jun 04, 2014 | Danby DWC283BLS Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
I have a danby wine cooler that is running hot. I am outside of the reg. warranty but if this is a compressor issue it is covered. How can I tell what is going on?
if the motor are running the gas level are too low . if the motor are not running check the thermostat. if there are power by the motor and stil not running then it is the motor
May 13, 2009 | Danby DWC283BLS Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Leaking water from the back
make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
Apr 09, 2008 | Danby DWC310BL Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Jul 31, 2007 | Danby DWC513BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
601 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
