Question about Sony Playstation 3 (PS3) Console
Ps3 shutdown i got a japanesee ps3 which i used my stepdown bought in maplin, however the ps3 did power up & was working then suddenly it turned off & never to power up again.what has happened?
  • genrlj1596 Aug 13, 2008
    same exact issue ...turns on then flashing red.....then solid red light
My ps3 shuts down as soon as i turn it on.
The light turns green then yellow, then red, and then it starts flashing red.
Does anyone know how to fix this frustrating problem?
Posted on Aug 09, 2008
I recently bought a used ps3 which came with Hamilton cables only my tv does not use hdmi so I bought av cables but it does not work! What do I do?
You need to reset the PS3 Display. Do This Touch and Hold Power Button On PS3 until it turned off automatically. Then again touch and hold PS3 and you will here beeps. Let go off power button after second beep.
Jul 18, 2013 | Video Game Consoles & Games
I am having problem with by bluray drive, it will accept disc but the mortor will start spinning then suddenly stop and repeats. i have bought a new laser and thsi problem still occours
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Also you might need to replace the motor..That will do..
I wish you good luck
Aug 10, 2011 | Sony Playstation 3 (PS3) Console
My ps3 was working fine untill i bought need for speed and now it wont read any discs is this something i can sort my self or is it just gunna result in me throwing my ps3 away?
restore the firmware
Step 1:
Turn off your Playstation 3.
Step 2:
Hold the power button down. The system will turn on and turn off once again.
Step 3:
Once the system has been shutdown, re-press you finger until you hear 2 consecutive beeps
Step 4:
Step 5:
You will be promted to plug in your controller via usb and then hit the PS button
Step 6:
The Recovery Menu will pop up.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
Power won't turn on
I had a similar problem to this. It turned out that the button on the main circuit board was broken. Take the cover off the printer and look at the main circuit board for any damage. I replaced the broken button and the printer turned on right away. Another option you can try is to replace the entire board if you can find a "parts" printer on ebay.
Jun 04, 2010 | Alps MD 5000 Thermal Printer
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
I have a TEAC 500 amp. It just cut out when I was listening to music. Now there appears to be no power (unit does not light up), but the power outlet sockets are still powering the other components - so...
More than likely, the internal regulated power supply has gone bad. The power outlets going out are usually just straight wired from the incoming power source, and not run through the power supply. Good luck!
Nov 07, 2009 | Teac A-H500 Amplifier
After a sudden Power shutdown - The ps3 is not working correctly
Hi, this sounds like your hard drive is not booting up. When that happens, all you will get on the screen is the Sony start-up screen (the screen with the swirly lines) and nothing else. Try taking out your hard drive and reinstalling it. Sometimes doing that will cause it to re-boot. If it dosen't then try it in another PS3 and see if it does the same thing. If it does, then your hard drive more than likely suffered some damage and will have to be replaced. The good news is they are not very expensive to replace and you can buy them at any Radio Shack, Wal-Mart, ABC Warehouse, or any other electronics store.
Aug 26, 2009 | Sony PlayStation® 3 (80GB) Console
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
Plugged in not charing, power available 92%
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Jun 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Sony Playstation 3 (PS3) Console Logo
947 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
