Question about GE Advantium SCA1000H Convection / Microwave Oven
Advantium Bulb replacement
This is not the typical bulb replacement question for the Advantium 120, SCA 1001HSS model. Most of those questions are referring to some little haolgen bulb near the front of the unit that I never even realized was there. My issue is the large interior compartment buld in the top center of the compartment taht runs parallel to the 500w halogen bulb. This is the one that lights up the entire compartment when the door is opened and also when the unit is in standard microwave function. It looks like it is a tube-style bulb about 7" long. To access it would be about that same as replacing the 500w halogen bulb, I would guess. When I talked w/ GE and had a certified technician come out to the house, he had absolutely no idea what bulb I was referring to. (He also wanted to charge $176.00 to replace that $3.95 halogen bulb, so here's where GE itself comes into question). Please tell me if this is something that can be done on a DIY basis. Thanks.
  • pjcain Nov 13, 2008
    Advantium 120 Oven, SCA1000:
    When the door is open or regular microwave is in use, no light comes on. When using Speedcook, the light cycles on.
    The owner's manual only has instructions for changing the exterior light.
    Where is it located and can it be replaced by me or does it require a service call?
  • Anonymous Feb 08, 2009
    I cannot figure a way to access the bulb that lights up the inside compartment when the microwave is in use, or open.
  • 5 Answers
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Posted on Nov 18, 2008
I need to replac the bulb in my ge advantium. what kind of bulb
Hello. Use a 35 watt halogen bulb with a GY8.6 base. Lowe's part number 15797.
Regards, --W/D--
Apr 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1000 top rear cooking bulb blown
Hi
Thanks for using FixYa. First please disconnect the power of the main fuse or circuit breaker panel and remove the screw from the side of the light compartment cover and lower the cover until it stops. Now gently pull the bulb from the receptacle. Raise the light cover and replace the screw and then connect the oven with the mains and switch it on.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 25, 2009 | GE Advantium SCA1001SS Convection /...
Replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Nov 26, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Ge advantium 120 microwave
STEP-BY-STEP:
Doug
May 21, 2007 | GE Advantium 120 Convection/Microwave Oven
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
STEP-BY-STEP:
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000H Convection / Microwave Oven Logo
1,313 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
