Question about Cameras
Sanyo exacti - CCD likely -
Hello and thank you on the sanyo exacot camera. I did the reset settings in the options menu - is that what you wanted??? I can see all the menu settings fine.
  • 983 Answers
Now can you able to take the picture???
Posted on Apr 12, 2008
I cannot use my camera properly
Complete reset is not possible. The language and date and time stay as they are. But you can set back shooting options. For that press the menu button and goto the second logo from the top, the camera/ Shooting Menu: Shooting Options.
The first line of the menu is Reset shooting menu.
Press there and follow the options.
Then you can reset the custom settings.
Third logo on the left in the menu. The pencil and called Custom Settings. Press that and chose line 1 again.
Jan 19, 2014 | Cameras
When turned on, my Olympus 700 Stylus digital camera shows a thin green vertical line on the right side of the viewfinder--7/16 of an inch to the left of the right edge of the viewing area. Part of this...
this is a problem with your CCD and not any software fault
and so best solution wil be to get this serviced by authorized service center
Oct 05, 2008 | Cameras
Sanyo HD1000 exacti
Hello there.
At a first guess, i would say you have the video quality settings on the camera too high. These new cameras and video recorders can store very high definition images and at the highest setting a laptop will have trouble playing the footage back without skipping or artifacting.
I would recommend checking the camera settings and lowering the resolution to something more manageable.
If you are unsure of this please write back.
Hope this helps.
May 03, 2008 | Sanyo PLC-HD10 1920 X 1200 6000 LUMENS...
My exacti wont turn on
"my exacti wont turn on"
Hmmmm .... did you put good batteries in it? Digital cameras are kind of particular that way.
Jun 29, 2011 | Sanyo Xacti VPC-T700 Digital Camera
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
All of the icons are still visible, but otherwise, the screen of my t99 is showing up blank. The camera still takes pictures, but the photos are black and so is the display. Please help! No temperature...
This may be due to the CCD Image Sensor failure in the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
Jan 18, 2011 | Sony DSCT99 Digital Camera
The screen on my camera is black. You can still see the text on top of it, the battery meter, and the flash sign but other than that, it's just black.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
Jan 17, 2011 | Sony Cyber-shot DSC-WX1 Digital Camera
Kodak C140 Photographs are blurry with lines. Video okay.
This sounds like a ccd problem, but may not be.
No matter, the camera needs some kind of repair.
Get in touch with Kodak, they may fix the camera for free if the ccd is a problem or damaged from the factory.
There may be other problems such as a loose cable in the camera itself.
The video is moving, but probably has the same event lines, but may be hard to see because it is a moving picture.
To test it to see what the menus are like, turn on the camera and run the menus. If no lines are in the menu screens, then the ccd is more than likely the problem.
Also, you ,may want to try this: Reset the complete menu back to the factory settings, most cameras have this setting. What tis may do is to reset all settings and may solve the problem...if not at least we tried.
Aug 23, 2009 | Kodak EasyShare C613 Digital Camera
Cant take picture
i think the ccd sensor is gone ....
if you can access the menu options then it is confirm that there is no firmware problem ...
if you can access the menu options just try giving reset once...
if problem persists then exactly ccd sensor is out...
you must contact the service showroom ...
it is fixable....
any doubt reply me ..
i am always here to assist you ..
thank you
bye
Apr 15, 2008 | Mustek DV5300SE DIGICAM Digital Camera
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
