Old tv samsung txb2025
I do not have a manual so I don't know how to program in the channels. Right now all I get is 2-13
  • 4 more comments
  • Anonymous May 15, 2008
    I have the same problem
  • jillbird May 21, 2008
    I can't get into the menu to find out how to program the channels.
  • vony72 Aug 29, 2008
    if anyone has fixed the problem please write the answer.i am truly at a loss here
  • mmesc1 Sep 01, 2008
    i have the same problem. Any solutions?
  • pandlhubbard Nov 02, 2008
    I have the same prolem and don't have the original remote, no button called f-set so can't get to that menu. Any help?
  • fogoso18
    fogoso18 May 25, 2012
    Hook up your vcr to you tv. Put tv on ch 3 and turn on tv and vcr and push the tv vcr button until your vcr remote can change channels
On your remote control, find F-SET.
After clicking that, you'll see choices, including TV/CATV ... there are three choices there, you want STD or HRC. That should get you the main cable channels that do not require a box.
Posted on Oct 06, 2008
I need to block channels, but don't have the access code for the v chip program. my tv is old and I have no idea where my manual is.
Hello
Just enter into this link. You can download the user manual for your Symphonic set. It will guide you how to enter the V-Chip functions.
www.funaiservice.com/manual/SYMPHONIC/Manual/ST413E.pdf OK
Jul 15, 2011 | Symphonic ST419E TV
I have a new Memorex LCD MLT 1921. I don't have the manual. I don't know how to program the TV and/or the remote to get the channels I need to watch. How do you do it? Thank you very much! I...
You can download and print your TV manual, at no cost, here:
http://www.managemylife.com/mmh/owner_manuals/15560/MEMOREX-LCD-Television-L0910312
May 09, 2011 | Televison & Video
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
My samsung lcd tv is lock on tv channels only
reprogram all the chanels, go to set up then auto program,after you finish sort the desired channels,or you can store it manually
May 14, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
Tuning VCR into Tv
Set the LCD to TV source and tune the LCD TV channel to 3 or 4.
For best viewing experience, you should connect the LCD TV to the VCR using component / SVideo or RCA cables instead of RF coxial to avoid signal loss. Your VCR manual should indicate these types of connections.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Jan 15, 2008 | Televison & Video
Televison & Video Logo
405 people viewed this question
Top Televison & Video Experts
