Question about Nikon D200 Body Only Digital Camera
Problem with importing images to laptop(macbook) from nikond200 trough data cable
Iam having problem to import images from nikon d200. throug data cable.i dont use any CF card readers i import directly from camera (d200) ...when i connect to pc or macbook, in fraction of second its showing connecting to pc but not connecting to pc or macbook what to do please check our this video and help out thanks alot...
  • 111 Answers
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Posted on May 16, 2008
I am thinking of using Vivitar Series One 28-300mm f/4.0-6.3 Auto Focus for Nikon D2x...! Does this have aimage stabilisation motor in it?? Do u recommend this for the camera??
I don't think it has image stabilization. If you use a tripod, stabilization is not important. If not, you can increase your shutter speed to compensate. Vivitar makes fair quality lenses, but you have a Nikon. I presume that you bought your Nikon because you want top quality images. If it is a matter of money, I would wait until I could afford a Nikon lens. As an alternative, consider used Nikon lenses. I generally carry a 10-24 mm DX, 28-105mm and 70-300 mm and a 60mm macro when I travel and it works well.
Sep 20, 2013 | Nikon D200 Body Only Digital Camera
I am using Nikon Transfer on my Macbook Air with my Nikon D3100. The software on teh PC says, 151 photos selected and transfer successful however i cannot see any of the photos in the provided default...
Pictures are normally stored in:
Option 1:
Nikon Transfer stores the pictures in a user selected folder. To fine it, look:
Option 2:
1. Remove Nikon Transfer 2. Have iPhoto import the images into the iPhoto library (~\Pictures)
Jun 27, 2011 | Nikon D3100 Digital Camera
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.-
Mar 28, 2017 | Computers & Internet
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
Nikon Coolscan5000 won't work with 10.5.5 Leopard
I just made a post to this site... The only work around I have found to work is this:
Put the plug-in into the import/export plug-in folder for Photoshop. Then, import the slide directly through Photoshop's Import function.
Hopefully this helps...
Dec 22, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Unwanted flash fire in nikonD200
Hi, I had the same sort of problem. It started with erratic small flashes but then evolved to the SB-800 not regonizing the D200 at all. The result of this is that I only get TTL and not TTL+BL+FP functionallity.
To solve this I cleaned the hotshoe on the D200 with all purpose cleaner for electical appliances (CRC 5-56). This gave minor improvment. Then I adjusted the spings to the left and right on the hotshoe on the D200 to press harder against the flash's connection (which I suppose is the grounding). Now everything works again.
Best regards,
Jun 21, 2008 | Nikon D200 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
The symptom you describe sounds like an incorrect white-balance setting when you take the images. Digital cameras are sensitive to the quality of lighting seen when your taking pictures. First thing to try is to manually select a white balance setting and try the photos again. Try google or your manual to find instructions on how to do that. The camera can auto-adjust to some lighting situations, but fails to properly compensate in other situations resulting in the muddy or yellowed images you have seen. There is a product called "expodisc" that corrects for this white balance problem as well. Look it up. David Millier Advance Camera Repair
Feb 21, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Body Only Digital Camera Logo
437 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
