Hi :) my dlink adaptor malfunctioned on my daughters computer we have another one but it will not let me install it any ideas would be most welcome kind regards bruce :)
  • 105 Answers
You have to check correct fitment, if ok. Check the Lan card is disabled in device manager. check for driver and uninstall the driver first and install latest from manufactuers site.
Posted on Apr 17, 2008
Can't install DLINK USB on Windows 8?
You must use a wired connection to update the drivers
if possible for the usb adaptor
as you don't post the model number for the usb adaptor it may not have drivers written for Windows 8 available
Aug 01, 2017 | Computers & Internet
When i put my d-link dwa-130usb adaptor in my computer it says i need drivers to install the adaptor where do i go so i can download that driver
> Where do I go ....
See: http://www.dlink.com/support/
Enter 'DWA-130' into the input-box just below "Product Support & Downloads",
to find downloads for your D-Link device.
Jul 19, 2011 | D-Link DWA-130 Pre-802.11n Wireless...
D link 2340 adaptor quit working
It sounds like you have done a bit of troubleshooting and I agree it sounds like a software issue. Have you tried toing to the dlink site for updated drivers? If infact it was a microsoft update then perhaps dlink has addressed the issue at their end.
Aug 05, 2009 | Computers & Internet
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Can't find printer on network
1.How are you attaching to the network printer from your daughters computer? IP address, or by the name of the printer...Also make sure you check you are attaching to the network printer, and not local printer.
2. Install the Microsoft TCP/IP version 6 protocol on both computers by clicking install on your LAN properties, then restart PC. This should work!
May 13, 2009 | Microsoft Windows XP Home Edition for PC
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
D link usb adaptor
Hi Bazildog,
the message reads 'there was a problem installing this hardware: 802.11.bg WLAN An error occurred during the installation of this device: the data is invalid'. I am then politely asked to click 'finish' and a litle box on the bottom left of the screen says that the install wizard had a problem installing this hardware and it may not work correctly.
Thanks for your time
Nic
Jul 20, 2008 | Linksys BTOPENWORLD / WIRELESS UPGRADE 1 X...
Dlink not working on my computer that receives signal
visible & unavailable means that the wireless security settings are not the same on the recently formatted computer, as on the rest of the network.
Open the wireless configuration for any computer that can connect to the network and copy the security settings (wep or higher) to the unconnecting pc
OR
connect to the router by cable from the non-connecting pc, use the web interface at http://192.168.0.1 to read the security settings, and copy the settings to the unconnecting pc
then it will connect
Jun 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
