When trying to use my wireless internet connectin I cannot get my wireless passcode. is it on the 2wire box
    Sergeant:
  • 221 Answers
Your wireless passcode will be located in your router memory. You must log into your router and visit the link for wireless settings. It should be under security features in wireless settings.
Posted on Apr 12, 2008
New download of windows 7 won't retain or create internet connectins
Ok, this is conflicting... won't retain or create!! Doesn't it have to be created to retain it?
Did it connect before you downloaded windows 7? Exactly what happens when you try to get on the internet? Do you have the wireless switch on the laptop turned on? Do you see your wireless router? If so did you put the password in correctly? If not, it will never connect.
Jun 03, 2012 | Compaq Presario CQ62231NR Notebook
Forgot password to log onto internet wirelessly
Try this links: complete walkthrough and screenshot is in the link... thanks...
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
if your with AT&T try calling this number
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 05, 2011 | 2wire (2701HG-B) Wireless Router
Trying to hook up 2wire modem to internet provider?
there is a cd-less install or Greenlight technology in it. it will automatically startup once you open a browser, (preferably IE. However, if you don't see it, try pushing the reset button at the back of the unit for 30 sec. open IE, then you will see the installation page.
NOTE: make sure you know what your username and password is... for authentication purpose...
links that may help: 2 WIRE Activation keys
http://www.2wire.com/?p=268
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
if you are with At&T AT&T ' Yahoo! High speed Internet
Jul 20, 2011 | 2wire (2701HG-B) Wireless Router
Wpa pass phrase
Although the information you've left is very vague.
I'm assuming you want to know what the WPA passcode is so you can connect to your network to get online Xbox 360?
It will be the wireless password you use to get on the internet with a laptop of sorts. If you have a 2wire gateway/modem its on the bottom of the modem in brackets usually. I'd check to see who setup your wireless router and they'll be able to get you the passcode for your wireless.
Mar 01, 2011 | Microsoft Wireless Network Adapter Xbox...
How do i go about changing my passcode on my 2wire router?
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router.
Select "Wireless Configuration".
Click to change the password.
Oct 22, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
I turned off the power to my 2wire box - now I can't get it to power up and have internet. What do I do??? More details: I had turned off the surge protector the 2wire box is connected to - when I turned...
Hi there!. unplug the power plug of your 2wire box from the surge protector for 1minute and after 1 min, plug in directly to the wall outlet, not to the surge protector. try to unplug and replug as well the connection on the back of your 2wirebox and check the cable connection from the isp cable to the modem,, the last option that your going to do is to reset the modem of your modem/router but make sure that you know the settings of your modem and wireless settings if u have.. or contact your isp provide for further details..there is a situation that there is a problem from your dsl company connection, most dsl use telephone lines..
Aug 14, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
How do you connect to the internet on a laptop
I take it you are trying to connect wirelessly. You will first have to make sure your router has its wireless capability turned on. Read the documentation on how to do this. You might find the directions on 2wire.com.
Once you have made sure the router is actually broadcasting its SSID (the network name), you should be able to connect with the laptop. First make sure your laptop wireless connection is active. (You can usually see a little computer in the system tray with some little curved lines like this: )))
Right click on that and choose show available wireless networks. When you find yours, tell it to connect.
This all depends on how you set up your router. If you secured the network with a passcode, you will have to enter that code to connect.
Hope this helps you. You can always ask for clarification if you are having trouble.
Mar 27, 2009 | Dell Latitude C610 Notebook
Router password code
If you are connecting to your 2wire router wirelessly you need to put int he 10-digit WEP passcode, this would be a 10 digit number on the bottom of the router near the serial number, it is usually in brackets like "[6123234645]" for example.
Jan 21, 2009 | Computers & Internet
2Wire Wireless Modem 2700HG-G
access gateway.2wire.net
home network icon
wireless setting tab
channel dropdown box=11
save
P.S u should know ur PW to do this
Oct 14, 2008 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
