Washing machine shaking on spin cycle
Bought washer and dryer about a year and a half ago, currently out of 1 year warranty. Over the last month on spin cycle the whole washer shakes violently, with pressure on front seems to lessen, but will not go away, I tried shifting clothes on inside, no change, it worked fine up to this point. I also checked the level both horizontally and depth, adjusted feet, but no change. With lid slightly open I can see the inner tank appears off balance. Sears wants $260 just to come out for inspection, any suggestions before I make the call. thanks for the help
  • Fraffer Apr 23, 2008
    It is a Kenmore 700 series
    Sergeant:
  • 332 Answers
DOES YOUR WASHER HAVE A CONCRETE BLOCK ONTOP OF THE DRUM HOUSING IF SEE IF ITS CRACKED OR BOLTS LOOSE MOST WASHERS HAVE
2 STABALIZIN BARS. THERE AT THE BOTTOM OF THE WASHER ONE ON
EACH SIDE THE LOOK LIKE MINI PLASTIC SHOCK ABSORBERS THIS CAN MAKE THE DRUM UNBALANCED AND BANG AROUND ALSO HAVE YOU MADE SSURE ALL WASHER FEET ARE ON THE FLOOR... GOOD LUCK
Posted on Jan 20, 2012
    Genius:
  • 1,073 Answers
What is the brand of the washer along with the model nunber
Posted on Apr 12, 2008
2 Suggested Answers
  • 1073 Answers
SOURCE: Kenmore 700 series washing machine
check to see on the top of the basket if there is a balance ring it will look like a large doughnut if it has one and if it is loose or if the fluid in the ring has leaked out then this will cause the out of balance while in spin let me know if i can help 276 523 4434
Posted on Apr 25, 2008
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water remains in the tub after spin cycle
Sounds to me like the Water Pump is bad. Hopefully if your machine is less than a year old you can get it fixed for free, if you bought it new it will have a 12 month warranty on it. If not you can always buy the manual for your washer and try to fix it yourself.
May 15, 2010 | Hotpoint Aquarius WD63 Front Load...
My ge washer wssh300g1ww does not spin out clothes well
Hello, I too bought one of these washers(WSSH300G1WW). After about one year of operation i noticed that the low spin cycle was making noise so look at it and it was just making noise and not spinning. canceled the cycle restarted the machine but this time set the spin speed to high instead of low, it works on high. im guessing its the clutch in the machine that is faulty and really cant affoard to fix at this time. The thing is i liked to use low spin cause the thing would shake violently on high even with a small load. So now when it spins or i start the machine i make sure theres nothing close that its shaking will cause to fall and break. I also bought the matching dryer (dsxh47eg1ww) it too has problems, the bearings that hold the front of the drum up are going out, thing is i dont over load it and it seems that they went out or started to go out very early as my clothes were getting caught inbetween the drum and the dryer 2 months after i bought it. Im 42 years old so i remember when we had REAL washer and dryers. When quality was revered by companies and consumers. Those old machines ran for years (maybe even decades) without problems, replace a belt from time to time. Now days your lucky to get five years out of an appliance. I know these ones arent going to see 5 years. their about 2 years old and im ready to go find some 1970 model year washer and dryer, rebuild, give a custom paint job to call them retro.
Jan 22, 2010 | General Electric WSSH300G Front Load...
GE WHRE5550HWW Excessive Shaking in spin cycle
Replace your stablizers, one of them has broken.
Dec 16, 2008 | Washing Machines
General electric washer won't start
no what happens is the control shakes and the solder in the board gets lose only fix is a new board sorry
Dec 13, 2008 | General Electric WCVH6400J Front Load...
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Apr 25, 2008 | Washing Machines
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
446 people viewed this question
Top Washing Machines Experts
