Question about Garmin StreetPilot c340 GPS Receiver
C340 help my garmin c340 automatically wa in another country .That corrected itself but now it wont let me type in a state. I goes blank. It used to default to penna where I live
  • Kevin Miller May 11, 2010
    Have you tried resetting the unit? Have you done a Master Reset?
  • 504 Answers
Has resetting this unit helped you? Are you still having this issue?
Posted on Apr 20, 2008
My Garmin thinks I'm in Vancouver, WA not Vancouver, BC. Have changed the country, but it doesn't recognize Vancouver as a city?
where to......address.....change state / province on bottom.......type BC
then spell city vancouver
Nov 25, 2010 | Garmin GPS
My Garmin StreetPilot C340 is not allowing me to enter an address - when it prompts for state it's blank and won't allow me to type my state, so is my food screen, lodging and fuel won't come up. Yet it...
There is a small pinhole on the bottom or right hand side of the unit for reset. Try hitting this with a paper clip or pin. If that doesn't help you may have to take it into a store.
Apr 14, 2010 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
H ow do i reset my garmin street pilot c340
To reset the Garmin C340 you will need to pull the Bezel off that goes around the screen. There is a reset button under there. Make sure that is what you really want to do before you do it.
Harleyknut
Mar 30, 2009 | Garmin StreetPilot c340 GPS Receiver
Blank screen. Not working at all.
Try to turn it on while it is plugged into the charger and see if it works. if not, you might need to update your software using this website: www8.garmin.com/support/collection.jsp?product=010-00401-20
Oct 22, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 settings
In order to get the unit to speak out street names, you have to have selected a voice that has a (TTS) next to it. This stands for Text-to-Speech. Press the button that looks like a wrench at the bottom of the main screen. Then press the button that looks like a pair of lips. You should see a menu with language and voice choices. Make sure you see the (TTS) next to the one you choose. The unit should then speak the name of the streets for you.
Apr 17, 2008 | Garmin StreetPilot c340 GPS Receiver
C340 user manual
my garmin 340 use to mention the street name, now it just tell me to "make a left" " or " a right" without naming the street as it used to do. How do I get it back to mentioning the street direction.? Thank youy
Dec 06, 2007 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Nov 04, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin C 340 problems
I had the same problem and finally found the solution. If you go to "map Info" you will see the version of your preloaded Garmin map database. Well, look carefully because there is a box next to it. Apparently, it needs to be checked or "enabled" before you can use it. Once I did that everything started working. Why this isn't done from the factory is a mystery to me. This should be discussed in the quick start guide IMHO.
Aug 10, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
