Question about Refrigerators
GE Refrig runs short time and shuts off
We have a 5 year old GE fridge that recently began acting up. It will run only about 5 minutes, regardless of thermostat setting, then shuts off. The evaporator coils are clean, the compressor barely even warms up before shutting off. The freezer circulation fan continues to run. I suspect the main control board since blogs suggest that they frequently fail.
  • nixamousa Apr 12, 2008
    This a top freezer model.
  • robert samples May 11, 2010
    is this a top mount freezer or a sxs
    Genius:
  • 1,073 Answers
Could be a sensor, 6 dollars, could be the mother board, could be the compressor or overload, could be encoder board i would call factory service, some of these parts are high dollar
Posted on Apr 12, 2008
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Sub Zero 550 16 years old is running alot more recently. Also refrig. setting needs to be at 7 to keep food cold. not the usual 5.
not a expert just trying to help,, sound like you are have heat problems,, slid out the fridge and take panels of of the bottom and clean the dust out from under fridge if very dusty under there cause the fridge not to cool right ! hope this help you
Oct 07, 2009 | Refrigerators
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side
Peace Friend,
ngafm At your service!
you have a short in the board an have to decide is it worth doing this investment for this fridge.
How old is the appliance?
Well, this is a top of the line fridge, so you would probably make the investment to repair it!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig MODEL GTS22KPB defroster not running fridge warm/freezer cold
you need part WR55x10552 Main Control board it is embedded in the back wall of the unit with a cover plate about 6"X8" unplug and replace this board ctrls it all
May 28, 2008 | GE Refrigerators
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Door water dispenser tube in door freezing shutting off water.
Have had this exact problem this week in the field ... My advice is try a new main computer (these fail and do all sorts of interesting things) You can try to monitor the frz temp use meat style thermometer frozen in cup of water. Should be around 0. Also your refrig has a pre-chill cycle what this means is right before it defrosts it closes the damper to the refrig and runs for 2hrs regardless of frz temp. If board is running longer than 2hrs in this mode it may freeze that tube its so cold. Remove frz door(very easy) first put outside for 1hr in sun and thoroughly defrost door if you feel confident that the temp is around 0 than you actually needs a new freezer door, tube is routed in the foam too close to interior of freezer wall, foam breaks down,settles over time and gaps in the foam. A solved rating is for when your question is answered accurately>>>>>Thanks
Oct 03, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
