Question about Stoves Kitchen Ranges
Cannot put stove door back on mclary model - Stoves Kitchen Ranges
Hi, i have a eurolec and had the same problem. For ours the door had to hinged pieces of metal on either side of the door. To get the door back on we pulled the longer of the two pieces of metal as far down as the spring would allow (took a lot of force) and jamed a bit of metal (we used some slef tapping screws that we had) in their to stop it moving back. This is done on both sides.
You simply slide the door into place and then move it to the completely open position. Pushing the door a little more open allows you to remove the pieces of metal to be removed and then the door operated correctly
Posted on Dec 21, 2009
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How to put the glass back on the oven door
You will need to completely dismantle the door, you might also have broken some kind of holding device.
Type "Sears Parts Direct " for a picture of the parts of your stove.
You will need the model number.
Nov 26, 2015 | Kenmore Kitchen Ranges
Mcclary stove
One thermostat (sometimes at the back of the stove) is open/blown or the door locking assembly has failed. To open the door you may remove the back of the stove; take the door locking assembly apart to release the long wire that hooks the door close.
On some models you can see the locking the latching mechanism through a **** in the top front and can play with the mechanisms there to release the door.
Then you can begin to figure why the door latched in the first place.
Oct 20, 2013 | Kitchen Ranges
I have a whirlpool electric range model no. RF378LXKQ0. I removed the door and now I can't get it back on. I didn't relalize I was to put the pins in and I don't even see where they go.
**** the hinge to the broil position. Put a nail or something so the hinge won't pop back in the door when you go to put it back. Once ya have it back in the stove, remove the nail and close the door.
Sep 07, 2011 | Whirlpool RF378 Electric Kitchen Range
PUTTING STOVE DOOR BACK ON
Since you lifted it off you know that it slides on the spring loaded arms. If you are trying to do it by yourself it may help to have someone hold it while you guide it on. There should be some set screws on the arms you may need to loosen or remove so you can put it on and them replace the screws to hold it in place on the arms.
Feb 28, 2010 | Hotpoint RGB745 Gas Kitchen Range
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Whirlpool electrice stove storage drawer
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Kitchen Ranges Logo
262 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
