Question about Telex Copyette 1-2-3 Single Dual Cassette Deck
Telex copyette records only one side of tape. does't matter if button ab is up or down
  • Anonymous Nov 03, 2008
    where would i go to get this problem fixed in the west philadelphia area near west philadelphia pa 19131.
  • angry_Angel_ Nov 03, 2008
    the master head rejects the tape. it will not stay engaged to record. where is a place that can fix a telex copyette? is there any specialty store that fixed them?
    Sergeant:
    Champion:
  • 319 Answers
Mechanism is not switching probably due to slack belt(s)
Posted on Apr 23, 2008
Telex Copyette 123, getting different speeds when duplicating audio tapes.
You might be able to find someone to work on it but there is no parts support and not many people want to work on them for that reason.
Jun 29, 2016 | Telex Audio Players & Recorders
Telex Copyette 1-2-3: Master well wraps tape around the capstan.
Tape wrapping on a capstan shaft is commonly due to a sticky pinch roller or capstan shaft but is also because the take-up reel table does not provide enough torque or tension to gather up the tape. The Teac MTT160 cassette is a test tool we use to determine what the deck is doing torque wise. Telex probably has something similar. I worked with a guy who worked at Telex in the tape business- He did not talk about them much but he did say they had a lot of belts in them. Maybe you are just dealing with a belt that needs to be replaced. Lubrication also tends to be needed at every rotation point as well. That would include reel tables. I hope this gives you some help as Telex repairmen are getting to be like Hens teeth.
Aug 24, 2012 | Telex Copyette 1-2-3 Single Dual Cassette...
Meaning of facimile
fac•sim•i•le (f k-s m -l ). n. 1. An exact copy or reproduction, as of a document.
adj. 1. Of or used to produce exact reproductions, as of documents.
May 31, 2012 | Telex Stereo Copyette EH 1-2-1 Single...
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Our machine does not seem to be copying on all the cassettes. One is the only one that is working now and it is recording at a delay.
Is it that they are all working maechanically, but the recordings are duff? or mechanically it's failing?
If it's recordings, the heads will need cleaning and degausing.
If it's mechanical, probably the belts require replacing and the unit needs a service
Jan 07, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Telex copyette 1-2-3 you can hear both sides at the same time
Clean the heads, oil the spindles.
Basic problem is the tape alignment is off a little. Could be caused by too much tape tension causing it to wander.
Hope Ya Fix It. So ya can spread the word!
Feb 07, 2008 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Telex Copyette 1-2-3 Single Dual Cassette Deck Logo
329 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
