Question about Sony PlayStation 2 (PS2) Console
Online gaming through router
When hook PS2 direct from modem online works OK, Try to install through D-link router, won't pickup automatic. Try static install and either get error 603 or 612
Any help would be appreciated.
  • Dimeless Apr 15, 2008
    After I posted this I opened the DMZ, I thought this opened all ports , is this not so? , however I still can't get past the Sony dnas ****, no matter what (legal) games I try. Still get error 612, (timed out no response from DNS server)
    Thnx for reply .
    Sergeant:
    Champion:
  • 317 Answers
You need to allow full acces on whichever port the console is trying to get a connection though.
Posted on Apr 14, 2008
I have a used ps2 system (its in good condition), i love splinter cell games, i have splinter cell pandora tomorrow. The first time i got it it worked fine, all i just needed was to hook up the internet....
more than likely you need to reset your modem.
turn off the power on your modem. unplug the power wire from your modem and unplug the coaxial wire to your
modem.
wait a minute or so and
first hook up coaxial cable to modem
then plug modem back in try it again and hopefully you will be back on line.
You just have to reset your modem connection.
This has happened to me before too.
If you have a router do the same thing.
If it does not work try the same procedure one more time.
it should work.. Good luck
leave a good rating if you appreciate my help.
Mar 27, 2010 | Sony PlayStation 2 (PS2) Console
Router problems when using xbox live
This sounds like a problem i ran into a few years back with a ps2.
This is not a machine related problem this is a signal strength problem. Most likely you have too much cord in between the router and the X box try shortening that cord as much as possible.
If this doesnt work try calling 1-800-4MY-XBOX
they will run a few tests with you and confirm my diagnosis.
you might be forced to run Xbox lve directly off your modem in an extremem situation or consider upgrading your internet signal or router
GL
Comment for further help
Please rate advice as it will help me out
Apr 08, 2009 | Microsoft Video Game Consoles & Games
Can't connect my ps2 slimline wireless to play online
can not do wirless
can only be wired cause i was asked that not to long ago sorry just buy a multi ethenet cable conneter and another ethenet cable to hook it up to your ps2 that's all i can think of
Feb 10, 2008 | Sony PlayStation 2 Slimline Console
System Link
for a direct link to work you need to use a "crossover" lan cable. you can find these by going to your local circuit city or other electronics store. try using the router with the cables from each 360 hooked into lan ports 1 and 2 on the router. try it in the same room if possible. when i had a lan party i had to turn off the wireless radio of my DI-624+ wireless radio to solve the problem of the router dropping the connection.
also, be sure that both 360's network settings are either set to automatic for direct link, or have static IP (192.168.0.56 and 192.168.0.58 for example) and the correct DNS addresses (4.2.2.2 primary/4.2.2.3 secondary for d-link routers). the DNS of your specific router can be found by calling customer support for your router and asking for it.
Jan 13, 2008 | Microsoft Xbox 360 Console
Log in problems
  1. Turn off your PS2 console.
  2. Get your CAT5 Cable (link varies based on where your router or modem is).
  3. Put one end of the cable into the port of the Network adapter (or slim PS2 and PSX) port labeled "Network".
  4. Connect the other end in a free port in your router (or on the port on your broadband modem).
  5. Turn on PS2.
  6. Turn on modem (or router).
  7. Put in online game.
  8. Go to the online section in the game.
  9. Create a network Configuration
  10. Load it
  11. Create an ID.
Jan 09, 2008 | Sony PlayStation 2 (PS2) Console
Cant get online?
  5. Turn on PS2.
  10. Load it
  11. Create an ID.
Jan 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 playing online madden with the network adaptor
  5. Turn on PS2.
  10. Load it
  11. Create an ID.
Jan 05, 2008 | Sony PlayStation 2 (PS2) Console
Need help!!!!!!!!!
There should be a setup disk that came with the network adapter.
Put that in, and it's a simple walk-through.
If you don't have it, then Madden 08 has an automatic connection sequence, just go online with it, and it should do it all for you.
If you have a cable connection (Cable Broadband), then its going to DHCP connection (or automatic) If it's DSL, then you may have a static IP address, and you may want to contact your ISP for further help. You would need to manually assign an IP address to your PS2.
If you have it set up correctly, and its a cable modem you've got, then you may want to reboot everything.
Unplug power to the modem and router and also make sure the PS2 is off.
Plug modem back in, then router, and turn PS2 and try connecting agian.
-Chad
Dec 12, 2007 | Sony PlayStation 2 (PS2) Console
Online gaming
did u make an internet connection on that counsel?...using the provided disc that u got wen u purchased it...also...remove 1 of ur routers...u only need 1, and both gaming councels and PCs don't like twin routers. u do need a memory card too...=3, im sure u knew that tho...lol
Oct 28, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
