Question about GE Lands Phones
Ge Cordless 5.8GHz model tc25951ee3 cuts in adn out, not loud enough barly can hear people talk.. speaker cuts in and out. we do have the three headsets is that the problem
5 Suggested Answers
PungaA
  • 91 Answers
SOURCE: Can't deactivate headset
Did you check the connector on the bottom of your phone ? If theres any greenish stuff (oxidation) on the connectors/pins, there's your problem. This occurs if the connector has been exposed to moisture. If this is the case you can try to clean off as much as you can and it might correct the problem. But if this doesn´t work, the problem might be inside your phone. If you're up for it, you can take it apart yourself and try to clean the inside of your connector. If youre not up for it, or the connector is clean, take the phone down to your local service-center and have them take a look at it.
Posted on Oct 05, 2007
ziraffa
  • 827 Answers
SOURCE: i have sound problems with skype, speech cutting and a lot of noises
if you right click on the realtek audio manager at the bottom right hand corner of yr screen, then hit the microphone tab, you might be able to run 'acoustic echo cancellation'.
otherwise, turn up your microphone a bit, and make sure you have enough bandwidth, ie your not running torrents or have msn messenger sending or receiving a file or something (or indeed running at all, it is sucky bloatware hoho).
try turning the pc sound down a bit and the skype volume up a bit.
otherwise we just have to wait for skype to improve, as i'm sure it will do as more people use the service. good luck..
chris
ziraffa@hotmail.com
Posted on Dec 13, 2008
SOURCE: we need a manual for cordless phones - lost ours
Here is a link to the GE website with manuals. I found 5922 EE1 and EE2. I wasn't able to find FE2, but I bet that one of the 5922 manuals will probably help...
http://www.home-electronics.net/ge/pc/user-manuals.asp
Posted on Dec 28, 2008
SOURCE: ge cordless model 27831 issues
you have to place the handset 2 in on the main base by 'round 20 seconds so it will be registered by the system
Posted on Jan 02, 2009
SOURCE: model tc25951ee3-a GE 5.8 cordless
Try this.
Please the 2nd handset on the main base cradle for 20 seconds to re-register.
This should solve the problem.
vision05
Posted on Mar 13, 2009
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to download a copy of the manual.
Jan 08, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Our line one cuts out even when we're talking on it & we can just barely hear the person on the line but they can hear us clearly. We have unplugged the phone's power cord & plugged it back in...
I have the same sort of problem...kinda..lol. My Vtech sorta 'cuts out' when there is noise at my hosue. The person I'm talking to can still hear me but I can't hear them. If my son starts crying or there's any other loudish type noises on my end, it's like the phone is trying to cutout my background noise, but all it's cutting out is the person talking to me. It's not that the noises in my house are loud and I jsut can't hear the person I"m talking to, b/c if i cover the mouth peice then no matter how loud the sound in my house is i can still hear the person i'm talking to but I HAVE to keep the mouth peice covered. It's really annoying!
Nov 15, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a GE Cordless phone model #27909 dect. 6.0 i can hear people talking to me, but they can not hear me....what is the problem?
that is probably your mouthpiece, it is located on the lower end of your handset and you have to open unit first to have it replaced. you could check that it has contact and nothing is blocking it before replacement.
Regards
Aug 19, 2010 | GE 28111EE2 Cordless Phone
Model tc25951ee3-a GE 5.8 cordless 2nd hand set states unavailable and have lost the manual for this phone. Can someone help me to solve this problem? thanks !
Try this.
vision05
Mar 12, 2009 | Uniden Cordless Phone
Speaker phone volume keeps going loud and quiet
Did the location change, a Echo from a wall or vibration from the table. It is a one way sound, someone talks and you hear. As soon as you talk it cuts out the speaker even if they are still talking and it transmitts what you say. So any noise in the room could trigger the the transmit mode even an echo from the sound being turned up too loud. The mike is on the bottom of the base and can pick up table vibration and send it into transmit mode. So the person talking cuts in and out.
AL
Jan 15, 2009 | Sony SPP IM977 Cordless Phone
We need a manual for cordless phones - lost ours
Dec 28, 2008 | Uniden Cordless Phone
GE TC25951EE3 Brand new
need manual foe model tc25951ee3-a search and search and got nothing. i;m not impressed.
Jul 20, 2008 | Uniden Cordless Phone
Operating manual
why can't i just get a manual model # tc25951ee3-a Been searching for hours still no luck.
Jul 15, 2008 | GE 25952 Cordless Phone
All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Jan 28, 2008 | GE 25931 Trio Cordless Phone
Cannot hear person calling
I am having the same problem with the same model phone! The line works with another phone but not with the GE cordless. If I call someone with the GE cordless they can hear it ring and hear me talking but I cannot hear them speaking. Silver Spring MD
Sep 06, 2007 | GE 21028GE3 Cordless Phone
Lands Phones Logo
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
