NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
Program using the "Learn" Button
Program using the Multi-Function Door Control
Change a Known, or Existing Pin/Code
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
