Question about Hoover H120M Front Load Washer / Dryer
Hoover washer dryer saver 1300
The spin cycle is not working it rotates 3-4 times them stops. I have replaced the brushes but it still doesnt spin. any further ideas??
  • Anonymous Jun 18, 2008
    Happens on wash cycle too - will fill, turn drum, then stop, try to turn, not be able to, so go throuhg the rest of the cycle without any drum motion ineither wash or spin. But I CAN MAKE IT WORK by switching the machine on and off rapidly, and the drum will sometimnes seem to re-engage with the cycle. If it doesn't, the most noticable sign is a very loud whirring from inside the machine. I can do the on/off stuff a couple of times, and the machine will carry on and do a complete cycle without any trouble. The next time the drum may again stop in the wash cycle, and need the switch turning on and off to get it to work.
  • fiddledom May 25, 2009
    I have had, intermittently ,had the same problem.
    The drum spins a few times at the start of the program where it shouldn't and then at the end but not up to full spin so the clothes end up clean but wet in the drum- will try above
    I had thought it was a blockage and took the thing apart, but no apparent blockage, checked the drum rotates ok and the motor seems ok... will try the on off thing....
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Posted on Aug 22, 2011
I have a hoover spin dryer that will only gravity drain.Whats my problem?
Posted on Jul 15, 2009
I have exactly the same problem on the same washer , but know just will not spin so called a repairer and waiting for them to call me back
Posted on Jul 25, 2008
How to fix, no spin on Hotpoint WDF740?
Long shot guess here but ...have you checked / replaced the carbon brushes of the electric motor ???? common problem I have had before.
If it is not the brushes then it could be segments of the motor burnt out which could be expensive.
Sep 07, 2014 | Hotpoint Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover Vision 1600 drum not spinning?
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Hoover H120M Front Load Washer / Dryer Logo
1,198 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
