Question about Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma No Video
When I turn the power on I hear the relay kick in but there is no video or audio. I took the back off and the LED blinks 12 times when I turn the power on. Does this mean that the 12V supply is gone?
  • Tongtae May 19, 2008
    I have same problem, no video nor audio. it blink 12 times. please help. Thanks
  • 4 Answers
To test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Posted on Oct 23, 2011
I am having the same issue, did anyone find a fix for this problem? Flashes 12 times and then clicks off and LED flashes 12 times and repeats the cycle.
Posted on May 17, 2008
    Genius:
  • Sanyo Master
  • 1,689 Answers
This can be a power supply failure, or a short on one of the boards. The flashing LED is indicating that the set is in "protect mode".
Jerry G.
Posted on Apr 12, 2008
My samsung plasma PN60E550 will output sound with no video. How do I know which component has failed?
Its the power supply not to exspensife to fix do you hear a click and the red led display light come on
Sep 03, 2016 | Samsung Pn60e550 60" 1080p Plasma Flat...
Sanyo Vizon 42" Plasma DP42746 Was using tv when I heard a click and I lost all audio and video, could not change the channel or adjust volume. Tried unplugging and sitting for 10 minutes. Plugged back...
This is a common problem with these TVs. You can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had the same issue with my TV last year. The solution is almost always to replace the Power Board (Y-Main) and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop): 1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Aug 03, 2010 | Sanyo DP42746 42 in. Plasma Television
When push the power button, I can hear a relay click but the unit will not power up. I took the cover off and fuses are good. Can't find anything in the trouble shooting section of the manual. What do you...
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
Sep 30, 2009 | Yamaha RX-V1500 Receiver
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
Sanyo dp42746
Problem is on the Y sustain pwb, to the left of the power supply. To varify, unplug the connector from the power supply going to the y sus. The set should then start up, and you'll have audio. Call sanyo at 1- 800-877-5036 for parts. Or www.shopjimmy.com for used circuits at a discount price.
May 17, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
550 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
