Question about Toshiba Satellite A60 Notebook
Wireless indicator how do you move the laptop wireless indicator it says in the manual that you slide the switch but it has no room to slide and it wont
    Genius:
  • 1,554 Answers
Some slide some push on/off
the manual is not for all models
there are models within models that the manual does not cover.
I assume yours is push on/off
mine slides
Posted on Apr 13, 2008
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
Help me please, my Dell V505 will only show a orange wifi sign indicating a bad wireless signal. What can i do about this?
Hello emma.
Has the printer always worked fine from that same location or was the printer in another room.If it was in another room then you might have to either move the printer back or bring the wireless router closer.
Step 2.
If the printer has always worked fine from that same position then it might not be able to connect to the wireless access point.
You either need to switch off the router /wireless access point and printer at the same time for about 1min and then try again.
Try to switch off the printer first and unplug from mains for 5 min and see if this solves the problem if not then step 2 is required.
You can download the user manual from here:
http://www.dell.com/support/Manuals/us/en/19/Product/dell-v505
And follow instructions to reconfigure the wireless section once again.
Aug 13, 2013 | Dell V505 All-In-One Printer
Iam unable to find a wireless radio switch on my E5400 DEll laptop
If you look at the very front of your computer you will see a switch on the left hand side of the bottom part (not the screen part) of your case. There is also a small led light beside it, as well as an indicator led that is beside the rest of the indicators that are just above your keys. Sliding the switch to the right should turn on your wireless card. In case you do not have you quick setup manual handy you can get a copy at the following website:
http://support.dell.com/support/edocs/systems/late5400/en/qrg/qrg_en.pdf
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 19, 2011 | Dell Latitude E5400 Notebook
Try find switch for wireless network
On the front bezel just to the left of the headphone jack is a Wireless switch/indicator. Slide the switch left or right to toggle - the LED should illuminate when wireless is on. The manual is available at http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire3680/Aspire3680nv.shtml
Jan 08, 2011 | Acer Aspire 3680 Notebook
Vaio VGN-NS328 funtion key to turn on the wireless internet
Your laptop uses a wireless "Switch" located on the front edge of the laptop on the far left side. There will be an led indicator light to the right of the switch itself. Move the switch to the right to activate the wireless radio. Move the switch to the left to de-activate. Below is the link to the user manual for your laptop. It is in PDF format, so you will need Adobe reader to open it. I am also giving you a picture below of the front edge of your system.<br /> <br /> <br /> <a href="http://www.docs.sony.com/release/VGNNS300_series.pdf">http://www.docs.sony.com/release/VGNNS300_series.pdf</a><br /> <br /> <br /> <br /><img src="http://www.fixya.com/uploads/images/96F2F95.JPG" />
Aug 25, 2010 | Sony VAIO VGN-NS328J/S PC Notebook
Something is blocking wireless signal, i live in flat so in one room there is wireless router and in other room signal is very poor sometimes it's not connecting. i tryed 3 diffrent routers the last one is...
There are several likely causes, if the building has plaster walls it may have metal lath behind it blocking the signal.(this is fairly likely the cause) If there are high-power microwave transmitters within 2 or 3 km, can cause spotty interfering. Neighbors with a wireless router close to your wall can as well.
If you can move the router to a position across from the door between the rooms, you can test by connecting (wireless) your laptop near the router, then walk it into the other room (stay where you can see the router). If the laptop stays connected move across the room to a point where you did not have a signal previously, if you are still connected leave the laptop there and move the router back to its original location and recheck the laptops connection, if it is gone, it is your wall...
Apr 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How do I switch on the wireless capability?
u will see a slide button on front view of ur system it control both bluethooth and wireless. once u slide it the light change to blue and it indicate ur wireless is on
Nov 15, 2009 | HP Pavilion dv5-1004nr Notebook
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Wireless
U will probably have to take it to an expert.
Jan 29, 2008 | Compaq Presario M2000 Notebook
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
