Question about Epson Stylus R265 InkJet Photo Printer
How do I use only Blank ink on Epson R265
Most of the times I print Black and white so I think it is cost a lot to always print in color
    Genius:
  • 1,447 Answers
Are you using windows or mac? on windows go to printers and faxes under control panel, right click on printer and go to printing preferences and under advance put a check mark on the box that will say grayscale or black ink only.
On mac when you click on file print go to advance tab and print setting, select grayscale or black and white.
pls dont 4get to rate the solution thanks!!
Posted on Apr 12, 2008
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
Does not print, just a faint black print, the cartriges are half full.
your printer is a photo printer which consumes considerable amount of inks when printing... you may need to perform a head cleaning process to clear the clogg on your nozzle. this may consume your ink cartridges... i suggest that you convert your printer into a CISS (continous ink supply system) this is more cost effective instead of buying ink per ink as this shows the same output as the regular ones.
check out ebay for people who convert epson system to CISS
note: doing the head cleaning process always takes ink to force the clogg out of the nozzle tube
hope this helps
Aug 07, 2011 | Epson Stylus R265 InkJet Photo Printer
I have an Epson Stylus R265. It is telling me all
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson Stylus R265 InkJet Photo Printer
My epson photo R265 won't print without all of the colors working. I only need black and white. Is it possible? Thanks.
Sorry, but I believe that you need to replace the cartridge. The printer's POST (Power On Self Test) checks the ink levels.
Don
Nov 19, 2009 | Office Equipment & Supplies
I replaced the black ink cartridge but I can't print
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 08, 2009 | Epson Stylus Photo R260 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Blank print but eats ink levels
I would imagine that you are printing in black more than you realize. The color inks tend to last longer because they are not normally used as much. Also when you print in color you are always using the black ink to make the correct colors. So every print that you have, whether it be black only or color only, the printer is using the black ink to make the colors. I work in a copier business and printer business and this is a highly asked question. Hope this was of some help.
Jan 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
220 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
