Question about Maytag Neptune MAH6500A Front Load Washer
Maytag neptune modle MAH6500AWW
Water does not drain out of tub and Lr shows on the read out.
  • shannon677 Jan 25, 2009
    After running a load it fills up and just sits there. I try the spin cycle and its not turning. How do you check the motor
  • Anonymous Mar 12, 2014
    The water does not always empty from the tub after shutting off. I am told that it has a self diagnostic test to check for error codes. How do you retrieve these codes?
Maytag Neptune MAH6500AWW
When I start a cycle the door will lock, fill with water and then just sit there. I can hear relays clicking in the controls...
I have plugged the motor directly into the electrical service and the motor turns so I am not thinking it needs the motor controll/motor kit.
Where should I look next?
Posted on Nov 14, 2008
    Genius:
  • 1,073 Answers
It is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Posted on Apr 12, 2008
Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
Nov 09, 2016 | Maytag Washing Machines
Neptune error code LR, means what?
Maytag & whirlpool was recall Maytag Neptune MAH5500B.
Oct 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Maytag Neptune MAH6500A Front Load Washer Logo
855 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
