Question about Nintendo DS Console
DS Lite's top screen has horizontal black lines
The lines appeared when I was trying to fix a problem with my Lite's L-button. I had a look, cleared any dust off, and closed it up. When I turn it on, there are black lines allover the screen. Or at least, that''s what it looks like. It's affecting the bottom screen too, as the bottom screen's flickering a little too, but thescreen's still clear. The odd thing is, closing the Lite and opening it will cause the top screen to become clear for a split second, and then gets covered with lines. It's not a major problem (most of my games use either the bottom screen or aren't too heavily burdened but the top screen) but I want to know if it's fixable, and how much it'll cost to fix. Any help appreciated.
  • dsmoo Jul 05, 2008
    My daughter's DS Lite has small vertical blue lines on the top screen. They are not consistent and as she puts it they can "heal up" or be in different positions on different days????????
  • Kassandra Johnson Jan 16, 2009
    the top screen has vertical black and blue lines on it when i turn it on. What could cause that? Is it fixable?
I found a REALLY easy solution! the most likley problem is that there is dust in the GBA/DS game card slot! it corrupts the connectors (i dont want 2 explain how it gets into the system) so step one: wrap a small peice of tissue around the stylus(make sure DS is turned ON)
step two: LIGHTLY go inside the GBA/DS slot with the tissue wrapped stylus.
step three: shut down DS system and turn on again
problem solved! hope this helps.
Posted on May 28, 2010
    Problem Solver:
  • 5 Answers
You might need a new screen (ebay) or check the connecters......it might be in wrong..
Levi
Posted on Sep 25, 2008
    Guru:
  • 155 Answers
You have probably just disrupted the connector for the top screen, this would explain the black lines. This would also affect the bottom screen if two connectors were wrongly aligned causing power to flow through the wrong connectors. The screen being ok for a couple of seconds after you open the lid i cannot be sure why it does that but when i acquired a broken Ds the screen did that but then I replaced the ribbon cable and it was fine. You can buy the parts you would need (screwdriver and ribbon cable) from: www.consoleparts4u.co.uk
Hope this helps
Mowcius
Posted on May 13, 2008
The dual flush cistern does not empty when the buttons are depressed. They have to be held down to clear the toilet bowl. How can I fix this?
cisterns never completely empty as the setting of the mechanism to close the valve is activated when it gets heavier than the water supporting it
try allowing more water into the cistern on a fill by adjusting the water level control
get a plumber in to clean out the sewerage pipes as there appears to be an obstruction in the line
Jun 13, 2015 | Home
HOW TO FIX JVC LT47X788 PIC FADES OUT
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | JVC Silver Tilt/Tilting Wall Mount Bracket...
Was dusting monitor and computer area and now monitor won't come on. Have checked all connections.
I've experienced similar problems and the power button gets dust in it and it stops working. Try 'flicking' the power button to see if it clears it, that's what I do.
hold the power button firmly closed then suddenly release it - I use the edge of my nail to hold it closed.
Jan 18, 2013 | AOC E2343F 23 inch LCD Monitor
IAM TRYING TO TURN ON MY SONY DSC-W90 CAMERA BUT DOST NOT TURN ON AND LENCE FREQUNLY TRY TO OPEN CLOSE AND I RECEIVED MESSAGE ON LCD DISPLY TRUN THE POWER OFF AND ON AGAIN , EVEN I REMOVED AND FIX BATTRY...
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
Jan 22, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
The Top screen has a big black circle on it.
The top screen will need to be replaced. Your only options are to either to send it off for repair or to fix it yourself.
If you intend on fixing it yourself I have a couple of guides to help you...
DS lite dismantling guide.
DS lite top screen replacement.
Hope this helps, any problems or further questions please feel free to contact me via my profile page.
Regards,
SOD69
Feb 28, 2010 | Nintendo DS Lite Console
Reset ligth mantinece
Hello there:
If you are getting a check engine lite and you have the problem fixed just take the vehical to autozone and they will hook up the diagnostic center to the car and clear the light this is a free service Also if you dont have it fixed they can tell you what the problem is and give you some sound advice as to what you need to do to fix the problem ok?
I hope this is very helpful for you
Best regards Michael
Dec 12, 2009 | 2004 Toyota Highlander
Black line on the top screen
your screen is broken go to a electronic shop to buy a new top screen
May 17, 2009 | Video Game Consoles & Games
Nintendo DS Console Logo
6,068 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
