Question about Coleman Mach 15 Air Conditioner
Water leak When it rains, I get copious amounts of water leaking from the ceiling of my travel trailer. I assume there is some sort of gasket seal under the a/c. How would I go about replacing that?
  • 828 Answers
If you remove the air grill for the inside part you will find four screws which when tightened compress the seal gasket under the outside to roof. It may be a case of these screws being somewhat loose.
Posted on May 11, 2008
Why is my roof rv a/c leaking condensate water inside Pop Up
if everything has been cleaned properly, is trailer level. good luck!
Nov 04, 2015 | Heating & Cooling
Lots of rain water leaking into front passenger foot rest.
Are you certain it is rain water? It could be condensation from the A/C coil that fails to drain out of the drain pan, or possibly coolant from a leaking heater core. If you are certain it is rain water, depending upon the age of the vehicle, and possibly some other things, here are the possible options:
  1. Leaking door gasket.
  2. Leaking windshield seal due to rust
  3. Leaking windshield seal due to improper installation
  4. Leaking windshield seal due to acoustic (sound) over pressure (if you have extreme sound system with heavy bass)
  5. If you have a sunroof, if the drain hose comes down the passenger side door column, it could be leaking into the passenger compartment rather than drain through the floor pan.
Oct 29, 2015 | Cars & Trucks
Water leaks into trunk when it rains 07 suzuki Forenza
that be hands on checks. sure whole
my wild guess...
1: bad seal
2: collision damage not fixe
3: a cocroach that die in the upper part of seal (look)
Feb 04, 2014 | 2004 Suzuki Forenza
Water leaks
Have your windshield gasket checked. When it rains, and if there is a small hole in the gasket, water will travel around the edges and down the inside. It will flow behind the dash and finally onto your floor
Nov 07, 2013 | 2008 Ford Escape
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
My Integra has a water leak in the truck/hatchback area. The passenger side break light area has condensation in it also. It get very bad in rain(im from Oregon) to the point that all of the windows have...
either the gasket seal around the back hatch is worn or the light assembly has a bad gasket and water is coming around the light .the window may be leaking
Dec 01, 2009 | 1991 Acura Integra Hatchback
'03 Accord-water leak at rear driver side floor board
I had a similar leak on a 1995 Accord. I traced the issue to the plastic liner behind the door panel. The seal was broken at the bottom and water would leak from that to the rubber weatherstrip at the bottom of the door that seals at the plastic threshold molding. You can't really see it good until the door panel is removed. The water would drip until it puddled up enough to run over the threshold molding and under the driver's seat. This caused the floorboard behind the driver's seat to be soaked after a rain. I have resealed the plastic lining but of course it hasn't rained since. I'm confident this will solve my problem and hopefully provide you a new place to look for yours.
Sep 20, 2009 | 2003 Honda Accord
Trunk is full of water! 1997 Sentra
How do you know the trunk seal is not leaking? Did you sit in the closed trunk while someone sprayed copious amounts of water over it? The other most common leak spot is from one of the tail lights. There is a goopy material that goes aroung the tail light that is supposed to seal it. You can usually pick this up at a auto supply store. It can also be coming from a body seam in the trunk. Check the lights and then check the body seams.
Nov 29, 2008 | 1997 Nissan Sentra
Water leaking from A/C
ok this unit should have a silicone seal around the pan so water does not collect under it if old silicone is worn away scrape old silicone away and redo new silicone around unit so it sits properly make sure all the water is gone before sealing because you run the risk of mold build up under it; let it dry or help it dry thats up to you
but would like little more info on what this is on
May 07, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
198 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
