Question about Belkin (F5D7230-4) Router (587009)
I have a Belkin Wireless G Router and I live in a apartment comp. a friend of mine told me that the people a below me were geting free inter net. I just want to know how to find the belkin program on my computer and turn off the wireless transmission. I only use the wired and dont really need the wireless. Thanks P.S I couldint find the exact "what product is it about" topic
  • 221 Answers
On your pc, go to 'Start' 'Run' type 'cmd'. This will open the command prompt.
Type 'ipconfig /all' then hit enter key
write down the 'Gateway' ip address.
Open up your browser and type or whatever the ip address of your gateway is.
You will need the default username and password to gain access to the router configuration web utility (If you have the manual for the router it will be listed in there), or the username and password you set when you first setup the router.
The default is usually 'admin' for both
In the 'wireless' settings menu make sure the network mode is disabled and the SSID Broadcast is also disabled. That should do it.
Finally, drop a bill off to your neighbors for half of your internet service bill since the time you bought your router.
Posted on Apr 13, 2008
My router is situated in my bedroom and can only get on to inter-net when have ethernet cable connected to my router and laptop, when i disconect ethernet cable and take laptop to another room it will not...
Thank you for using FixYa
In order to use the laptop in another room, your router must be a wireless router. If it is a wireless router you will need to Create a new wireless connection on your laptop in order to connect to it. Go into your control panel or system and use the Wizard to create a new connection. Since I do not know what operating system or hardware you are using this is not a specific answer but I am giving you the general procedure that you will have to follow.
I hope this was useful and please comment if this was helpful to you.
Jun 29, 2011 | Belkin Computers & Internet
We have recently installed a Belkin Surf Modem Router. Since it's installation, we are sometimes having issues sending & receiving email. Internet and wireless connection are fine. We are able to...
I got your issue, you must make sure the firmware is upto date in your router since in the surf wireless router we have the issue only because of firmware.
Click here to download the firmware.
Update it in the router using a wired computer, if you do it in a wireless comp, connection will be disconnected.
I'm sure this will work.
Good Luck!
Thanks in Advance!
Dec 27, 2010 | Belkin Wireless Surf Router (F7D2301)
My belkin wireless router keeps losing my ip address and i have to recycle the modem and router to get it to connect.
Hi Friend,
You have to update the firmware for the router,You can download a free firmware from the below mentioned Website
If you have any clarification send reply
Mar 09, 2010 | Belkin (F5D8231-4) Wireless Router...
Xbox live
Some modem have built in router.So in my case i have hughesnet hn 9000 modem so what i did is connect my modem to a switch and from your switch connect to your xbox live. so buy a switch.
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Click Here for more info
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless can not communicate with my comp
I'm assuming you are using windows XP or similar. You can check your tcp/ip protocols and local pc adaptor by 'pinging'. open the command prompt - 'start', 'all programs', 'accessories', 'command prompt'. Then type 'ping' without quotes. If there is 'no loss' of data, your pc is basically sound, as are the protocols.
Try reaching your router by typing (or look on bottom of router or documentation for IP address). It may ask for user name and password which should be with documentation. You need to be able to reach your router before you can use the net.
If using a cable, check out your LAN by going to 'control panel', 'network connections', then find the LAN icon. Right click and left click on 'properties'. under the 'general' tab scroll to ' internet protocol tcp/ip'. double click on this. under the general tab make sure ip address and dns is obtained automatically.
If you're using the wireless capability (ie not network cable) right click on the wireless connection to 'view available networks'. try to connect to one. You may need a WEP/WPA etc password. You could try connecting a network cable from pc to router to see if it's a wireless problem or not.
In control panel look at 'internet options' and 'connections' tab. make sure it's set to use the right connection (eg mine just uses the LAN).
sorry if this is a bit muddled but there are many possibilities. Any more info on your setup would be helpful.
Dec 04, 2008 | Belkin (F5D7230-4) Router (587009)
Need to hookup router for laptop to access inter-net. I already have a Belkin Wireless G Router -2.4hz-802.11g. It needs to be re-configured after being shutdown.
connect your pc to router using a lan (RJ45 cable), then open up internet explorer and type or in the web address, you can then enter the default password and username and then set up your router
Aug 16, 2008 | Belkin Computers & Internet
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar u can see the belkin login screen and follow this link
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D7230-4) Router (587009) Logo
208 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
