Cars & Trucks Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The drlive line goes into what part - 1990 GMC Sierra
A Miller
Level 3:
  • GMC Master 8,404 Answers
  • Posted on Jun 13, 2010
A Miller
GMC Master
Level 3:
Answers
8404
Questions
Helped
2053196
Points
24677
The Drive Line is a general term that describes a variety of parts ...
Power starts with the engine ... power is transferred from the engine fly wheel through a clutch to the transmission ... through a series of gears to the 'tail shaft', the output of the transmission. The drive shaft inserts into the splines of the tail shaft. The shaft connects to the rear end where the power is divided between the rear tires through through a diferential. The axels connect to the diferential and deliver power to the hub towhich the tire is attached..
that is unless your car happens to be a front wheel drive ... which I dont think yours is.
Anonymous
Level 2:
  • Expert 666 Answers
Anonymous
Expert
Level 2:
Answers
666
Questions
Helped
247360
Points
109
The drive train (Motor and trans) Connect through the drive line (rear and or Front differentials) Via a Drive shaft or axel shafts depending on the vehical
Diagram power steering lines 02 Pontiac Montana
It's pretty basic, there is a high pressure line that goes from the pump to the rack, then a low pressure line that goes from the rack back to the pump.
Where do transmission cooling lines go on a 1999 nissan sentra
Since the transmission cooler is located in the radiator tank , the way to remember which line goes where is the transmission fluid will enter at the bottom allowing more cooling time as it goes up the tank and exits. The way to know which line is the pressure line is to start the engine and see which line pumps out the transmission fluid. Be careful when checking the fluid flow so that you do not make a mess. Put the lines in a bottle to catch the fluid.
Cant get fuel threw the fuel line when I take the fuel line off gas pours threw when I put the line on nothing goes threw
depending on the year and make check to see where the line goes on if a seal got pushed into the connector it could be blocking the line
The line beneath the passenger side on the frame of an 85 Ford f150 is that the fuel line or break line ?
joking, stab both with a ice pick
one leaks, DOT 3/4 and the other fuel. end joke
the one that goes to gas tank is fuel or vent
the one that goes to , brakes,is brakes,
use eye to follow the line, and bingo.
Have a 93 k1500 chevy did not have ac condenser i need to know witch line goes where
The line from the compressor goes to the top and the bottom line goes to the evaporator in the car. There should be a receiver/drier before the condenser that takes out any impurities in the gas including moisture from the air which damages the internals of an ac system. The line from the compressor goes to it ---from there to the condenser and the bottom line back to the evaporator. If you do not have a receiver/drier then get one.
Can't tell which line from the fuel tank goes to the in line and which goes to the out line on a 2002 chevy trailblazer.
If I were doing this myself i would hook up power to fuel pump and find which one is pumping gas,this will be the one that goes to fuel filter.
I need to know which fuel lines goes from the truck to the fuel pump. Which line goes where?
The fuel pump has two outlet lines. The thinner one goes back to the gas thank while the thicker one goes to the carburetor
Brake pedal goes to floor
there is still air in your hydraulic lines somewhere bleed the system with a pressurised power bleeder and you will get instant results
'98 sonoma fuel pump,which line goes where in the pump?
the line that feeds fuel filter is the 1 that connects to pump,other line is the return!
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
