This machine uses the latent heat, after the rinse cycle to dry the contents.
"Ariston L 63 B NA Dishwasher - Black, 5 wash programs & options (intensive wash, regular wash, eco wash, rapid wash, soak), wash sequence indicator; washing temperatures up to 160°F, dynamic drying (natural condensation dry); Water safety : Overflow; Platinum Multisystem Rack and Baskets; Adjustable Top Rack : standard; Built in Water Softener indicator light; Concealed heating element; Tub & Drum : Stainless Steel, Filter : Stainless Steel"
If the contents gets hot when washing, it will dry as described with the door open.
I would let it dry for 24 hours before using the dish racks.If you are going to leave the racks inside the dishwasher after you paint them be sure to leave the door open to help the paint dry.
Hi dear.Here is some help from the user manual.I hope that helps.Thanks.
DryingRack To use the drying rack Do not remove the lint screen. 1. Open dryer door.
2. Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3. Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4. Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
The rack is to dry things like sweaters or shoes that you would not want tumbling around. When used the items are stationary and the drum rotates around them. Low or no heat can be used to facilitate drying without shrinkage or damage. Eric
It is a trapezoid, the wide end goes toward the door and lines up with the lint trap. You cannot support two boots, or heavy shoes. It just balances in the rim of the door frame. The handle shaped things face down. You kind of have to pinch it into place, and it just rests there, too much weight and it will topple in. Good luck if you have big feet.
i dont have your model # , but on most models you take out lint filter and pu the rack inside the dryer drum.the one end of the rack that looks like it goes into something goes into the filter housing. hope that helped you ....
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
insert the drying rack into the dryer with the wire end resting aginst the rear wall of the dryer and the frount of the rack over top of the lint filter
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
