Question about Kitchen Ranges
Frigidaire Gallery Series
Model CGES387CS1 - both the baking and the broiler element wont come on, we checked the circuit breaker and thats ok. Can't visually see a break. We were cooking and then i noticed it wasnt working anymore, no smell, no noise....just silence...lol If one or the other element doesnt work, will both stop working? If there is a fuse, where would i find it? Any help on this would be greatly appreciated
When I turned on the oven, there was a flash from behind the clock, and then the circuit breaker blew. I remove the integrated circuit that is found behind the clock and part of it was melted. The part costs $320. I am wary replacing the part because I do not know the cause and am worried that the new one would blow too. If I get a technician in to replace it, it becomes his risk to replace the part, and so the total would be around $500 with tax. I am disappointed that this happened with a stove that is less than 5 years old and now wonder if is it worth it to repair.
  • 1 more comment
  • wccl343 Nov 14, 2008
    I could have written what you just wrote -- Exactly the same thing happened to our range -- 5 years old -- a flash -- popped the breaker --- and no more oven -- Clock fried and 400.00 repair bill !! . Repair man said don't bother fixing it -- too many of these ranges have the same problem. He claims to have serviced 4- 5 in the last month. So we will donate to the local landfill....
  • brucecraig Dec 23, 2008
    After 3 years of minimal use the EOC on my Frigidaire Gallery Series range just stopped working. $270 CDN for the new part and no guarantees. Give me the old ranges with no electronic touch pads.
    Genius:
  • 1,073 Answers
The control is bad and will have to be replaced, nothing need to happen for the eoc to fail i see them fail new out of the box
Posted on Apr 12, 2008
Why will my broiler work but my bake will not?
Good Afternoon Friend,
I understand that the broil element is heating in your Frigidaire oven, but the bottom bake element will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When you restore power you will need to set the clock. Preheat your oven using the bake option. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Ovens
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
316418305 broiler element and bake element will not heat
I see that you are having trouble with your Frigidaire range, model# FEF336BC, broiler and bake element not heating. I would give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn your oven on and if the elements are still not heating, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 23, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Not sure what went wrong here, but the email i got back says it is a fridge - as you can see i am talking about a stove. And no it hasnt been solved, but i am sure a repair man will be able to take care of it.
thanks anyway
Feb 10, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
378 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
