Question about Janome 8080 Computerized Sewing Machine
I have a Janome 8080 that is out of warranty by a month and days. I went to use it and my handwheel will not let me move it backwards. It is not giving me a code that anything is wrong. I can't reach Janome tech support, seems like their sewing machine, they are not working. Thanks, Gloria
  • 8 Answers
You should always move the handwheel forward. On some machines moving it backwards can throw off the timing. Try reverse and doing a couple of stitches to test.
Posted on May 20, 2008
Handwheel freewheeling
it could be the gears of your handwheel try spraying it with wd-40.
is it making any noise?
Jun 25, 2008 | Janome D'cor Excel 5018
Janome Harmony 8080 showing SP in the display and I can't find my manual. I know I've had this issue before and the manual had the solution but I without the manual, I can't seem to fix it
SP means the bobbin winder is engaged. Move the spooler (where you put the bobbin when you wind it) to the left and your display will go back to normal.
Feb 05, 2010 | Janome 8080 Computerized Sewing Machine
Will cords from janome 8000 fit a janome 8080
some of the cords are interchangeable and the foot petal are also.
Jan 24, 2009 | Janome 8080 Computerized Sewing Machine
The feed dogs on my janome 8080 will not come back up
This is a sign of lack of oil and it needs servicing. If you can remove the cover on the bottom and follow the connections from you feeddogs to the handle you will see a bullet shaped part that is supposed to move in and out of a hole. It is most likely stuck and needs oil. Give it a good cleaning while you have the cover off. Or take it in for service.
Good luck.
Dec 12, 2008 | Janome 8080 Computerized Sewing Machine
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
Manual
my sister has the janome 8080... it's listed at the Janome web-site as the DC3050..if you go to the (specifications) of that machine it has a manual you can download for free... hope this helps
Aug 30, 2007 | Janome 8080 Computerized Sewing Machine
Bernette 75 only backwards
check the motor it is deffected the brushes neeeds to be change.call a tech.good luck
May 02, 2007 | Bernina Bernette 75
Janome 8080 Computerized Sewing Machine Logo
135 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
