how can i exit from the rommon mode on cisco 1721 router
Comment by raveesh, posted on Apr 14, 2008
Dear team,
i changed the register value as per your instruction ,but still the router in rommon mode ,i hope the problem with ios ,if the router dont have valid ios image how can load a valid ios image in to flash memory ?
Does the router boot to rommon mode everytime you turn it on?
There are two reasons why the router could be booting to rommon mode
1. There isn't a valid ios image loaded in flash memory
2. The configuration register is set to a number that ends with '0'
Change the configuration register setting to a number that ends in '2'. (i.e. 0x2402)
You do this with the command: confreg 0x2402 <hit enter key> (in rommon mode)
Reboot the router and it will first search for boot system commands in the startup config, if none found it will boot to the first valid ios image in flash memory.
If there isn't a valid ios image in flash memory, the router will continue to boot to rommon.
Comment by Markk7171, posted on Apr 19, 2008
Here is a link to the cisco website where you can download ios software. You will have to create a user account first.
