Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
Dbox nokia 2
My dbox, says default gateway;is unreachable {host or protocol error} DNS server 92.168.150.1 is ureachable I get normal channels,but no cable,I may have made it worse by messing about with it trying in the network settings,cheers micky
  • 86 Answers
Is your receiver directly connected to your router via ethernet cable or are you trying to connect wirelessly? If wirelessly its probably your security settings at fault.
if via wire, it looks like you typo'd the gateway. an internal IP address will usually start with "192" not "92".
Posted on Mar 24, 2009
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Can't connect to router interface 192.168.1.1
Took another look by fixing word wrapping in notepad.
It's missing DNS Servers. Check your NIC settings and make sure you don't have a DNS server manually set to another IP. Plus, you might try resetting the router to default in case there is a DNS modification there.
I'm not sure if this is the cause, but I couldn't hurt. It's part of trouble shooting.
Good Luck!
JD
Oct 02, 2012 | Computers & Internet
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Intel Proset wireless just drops connection
    well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
    Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
    Billionton USB : Class 1 USB Bluetooth adapter
    before you try any step i tell you please disable your antivirus and firewall.
    well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
    Jul 01, 2009 | Billionton Long Range Bluetooth USB...
    I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once...
    Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
    Hurricane h5200 modem/router
    Hello jmazaredo,
    Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
    One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
    In other words edit your hosts tables (hosts file) with the entry (Example 1):
    IPADDRESS FQDN ALIAS
    192.168.10.2 somesystem.myhome.com. system
    192.168.10.5 somesystem2.myhome.com. system2
    This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
    Once this is done if it works then try this setup:
    1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
    2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
    3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
    4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
    I hope this helps.
    Thank you,
    Shuttle83
    Aug 14, 2008 | Computers & Internet
    Cisco asa5505 problem
    You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
    Is VLAN1 connected to the outside router or internet backbone?
    If not, change the last resort to the outside Ethernet port.
    Apr 16, 2008 | Cisco ASA 5500 Firewall
    Wrong ip address
    Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
    Mar 28, 2008 | Computers & Internet
    Configuring leviton router
    You can get the router's IP address from the functioning PC. Go to the command prompt by clicking on Start / Run ...and then enter "cmd" in the text area and click "OK". In the black window that pops up...type the command "ipconfig". The computer will list it's IP address, subnet mask and default gateway. The default gateway is the router's IP address.
    To enter the Default gateway (router) address in the PC that isn't working...click on Start / Control Panel / Network Connections / Local Area Connection / Properties. In the "Local Area Connection Properties" window....scroll down and click on Internet Protocol (TCP/IP) to highlight it. Now click on the properties button.
    In the Internet Protocol Properties Window....click on Use the Following IP address:...now you can enter the IP address for the computer to use, the subnet mask, and the default gateway. The default gateway and subnet mask are the same as the working PC. Hopefully you already know what the IP address for this computer is supposed to be....it must be unique on this section of the network. To function properly, this computer also needs to know what DNS server(s) to use. You can enter the DNS server address at the bottom of this screen.
    If you don't know the DNS server addresses, you can look them up on the other machine also. Use the command prompt as described above and enter the command: "ipconfig /all" Look for the DNS server addresses in the command output.
    Jan 14, 2008 | Computers & Internet
    Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
    211 people viewed this question
    Top Directv Televison & Video Experts
    john milligan
    Ed
    Level 1 Expert
    Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
