Question about Indesit Dishwashers
Indesit IDL 530 Dishwasher
Dishwasher will not start and left hand warning light flashes.
  • Anonymous Mar 18, 2014
    Seems to go through the cycle OK
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Posted on Apr 13, 2008
What's the section panels at the side of the indesit IDL 530 dishwasher for
several dishwashers come with side panels that allow the outside parts to be held in place and this aids in the units performance and lack of leaking, best to leave them on or intact.
Aug 21, 2015 | Indesit Dishwashers
My Indesit idl 530 dishwash which is fairly new has packed up with the Prewash and Drying light flashing simultaneously. I know it's under warranty but I'm trying to find out what this error code means and...
Refer the user guide for the error meaning. Switch off the machine and try.
Still the same problem contact the service engineer as this will ease your work!
May 17, 2010 | Dishwashers
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Flashing green light on my indesit dishwasher
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
Dec 05, 2008 | Indesit 24 in. D61 Free-standing...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705
if the pump is not humming or is humming but not pumping i would replace it.
Nov 27, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
539 people viewed this question
Top Indesit Dishwashers Experts
noel
noel
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
