WELCOME TO THE DREADED NORTHSTAR..THEY FAILED TO PUT A LOCKING SCREW ON THE IMPELLERS ON THESE WITH A MOTOR THAT CAN RUN IN REVERSE ON A WHIM . SO WHAT ITS DONE IS MUCKED UP THE THREADS ON THE IMPELLER.. YOU WILL FIND THAT THIS IS THE HARDEST PUMP TO WORK ON ! PARTS $$$ CRAZY .. I SEE A NEW PUMP IN YOUR FUTURE ,, A STA-RITE DURA GLASS !....; WHEN GETTING A NEW PUMP TELL THE THE HP AND SF SERVICE FACTOR OF THE HAYWARD YOU HAVE SO YOU GET THE RIGHT SIZE PUMP FOR YOUR NEEDS ..GOOD LUCK AND VOTE FOR ME...JAY
My Hayward Northstar pump all of the suddem seems to not run correct and them trips the breaker?? I just put a new impeller and diffuser two weeks ago and it has been running great.
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
