I have a disc stuck in drive E and it want open
  • 85 Answers
Drive E: usaually cdrom?
Shut off system use a straightened paper clip and place in small hole in front bezel of the cdrom and slowwly press in? Cdrom should release
Posted on Apr 12, 2008
Disc inserted improperly now stuck
Carolyn:
Take a butter knife (not a steak knife) and push the diskette into the drive the rest of the way, and then eject it.
Jul 12, 2015 | HP 19-2014 All-in-One Desktop PC - ENERGY...
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
Stuck disc in an acer aspire laptop
There should a small pin hole on drive. Use a straightened paper clip. Push in and it should open.
Aug 26, 2012 | OEM Systems Acer Aspire 5736z Pk400007v00...
How to open driver door
Do you mean the disc drive tray won't open? Or do you mean you have a front panel cover on your computer that won't open? If the disc drive tray won't open it could just be stuck, if you look closely at your disc drives front panel you'll see a small hole, take a paper clip our some thing about 3 inches long that will fit in the hole insert it into the hole you'll feel it bottom out if you push on the paper clip firmly your disc drive door will open, ( I would do this with the computer turned off) If there's a disc in there take it out if not just push the try back closed don't force it completely closed it will do that itself, now turn on your computer let it completely finish booting and see if it the drive works. If it does not it's probably time for a new disc drive. I hope this helps
Jun 22, 2012 | eMachines EL1360G-UW11P Desktop PC
The console is scratching the games in a circular pattern Antoine the disc. Why?
Chip or dirt, something stuck on the disc tray. Or theres something internal causing the disc to spin irratically. Open up the system Torx 9 drive will open it. and open the dvd drive to clean and inspect.
Oct 03, 2010 | Microsoft Xbox 360 Console
Cd put in drive, is stuck and will not open. Have
Power down.  Now power back up and press the eject button at the top of the keyboard and hold until disc ejects.  If that don't work, then you gonna have to open this thing up and physically take the disc out cause something is blocking it from ejecting.
Nov 16, 2009 | HP Pavilion Media Center a1330n - AMD...
Cd stuck
Take a paper clip and unravel it. Insert the paper clip into the small hole located on your CD player. The tray should eject.
Aug 04, 2008 | HP Pavilion zd8000 Notebook
Problem with disc reader
the motor that drives the laser is broke solution get a new drive or motor
May 04, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
