Question about Nikon D200 Digital Camera with 18-200mm Lens
Partially dead D200
I have a Nikon D200 that has started behaving oddly. When I switch the camera on, the control panel on the top of the camera seems to function correctly and I can auto focus and 'take' pictures. However I cannot get the LCD on the back of the cmaera to function at all, ni images are being stored to the CF card and the camera is not recognised when I plug in the USD cable.
I've googles for others with this problem but haven't found anything.
I removed battery and tried switching the camera of and on.
I cannot format the CF in the camera
I've switched from C to S to M taken operated the shutter and then gone back to C
I've tried the two button 'reset procedure.
I think I have to assume that the camera is now defective and should be returned under warranty. But before I do any further suggestions would be welcome.
  • spsoft Sep 19, 2008
    Exactly the same problem have with my Nikon camera D200 too, after 2 years of using.
    After some playing with the camera noticed that sometimes it started to work partially (only if the battery is fully charged), i.e. can read images from the CF and display remaining shots on the CF on control panel, but definitely after making a shot and trying to store it on CF, the camera dead again.
    I have tried also with different CF, but it is the same, so it is not the CF.
    Noticed also that if the battery is charged, e.g. at 30%, the camera start working even less (i.e. can't show focus area in viewfinder and can't focus and can't shot.)
    Shame on you Nikon, as the camera is just on <4000 shots.
  • Anonymous Sep 23, 2008
    Will not format cf
  • 48 Answers
Lick my arse
Posted on Jun 25, 2008
Can a Nikon d200 be Tethered to a laptop
I don't know what you mean with Tethered, but if you mean can I manage your camera on your laptop, you should look for
Camera Control Pro 2 - Full Version (Boxed)
look on the link here, to see your D200 is compatible with that software.
You always need software, when connecting a camera to a computer. Without the software the computer does not know what to do with the device.
Nikon does have other versions of camera control software.
Camera Control Pro 2 Full Version Boxed from Nikon
May 22, 2014 | Nikon D200 Digital Camera with 18-200mm...
Using 200-500 Tamron on Nikon d300. When I shoot, camera freezes. Clock and exposure readout next to it, on top panel, blink. Camera will not turn off, I have to take the battery out. Lens works...
Maybe there is something wrong with your batteries? Replace them. I had the same experience with my D200 and a Nikon 18-200 lens, later with my Nikon 10.5, Sigmaa 135-400. After replacing the battery everything worked as ever.
Mar 26, 2011 | Tamron 200-500 F5-6.3 DI AF Lens Nikon
My Nikon D200 refused to turn on!
Afraid bad news is correct, it sounds like main control board.... You will need to get a quote from your local Nikon Service Agent..... Good Luck
Aug 29, 2009 | Nikon D200 Body Only Digital Camera
D200 will not turn on
Have you checked for dirt in the camera battery compartment. Take some high powered air spray and blow it clean. See if that fixes it.
Aug 17, 2009 | Nikon D200 Body Only Digital Camera
Err, R25 on display
The D200 uses a different way of changing the aperture than on that old lens. Set the switch to 22 and lock it with the little lock just above it. It always has to set like this. Now the D200 will stop complaining.
May 16, 2009 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 images not sharp
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Apr 13, 2009 | Nikon D200 Digital Camera
I'm planning to buy a DSLR but confused what to buy
You have named several excellent digital SLR cameras aimed at the top end of the amateur/semi professional market.
I have the Nikon D200 and have been very pleased with it.
As stated by JCDill, you must really decide what you want and can afford. The camera body you choose will commit you down one path or another. For example, if you choose Canon, only Canon or OEM (Other Equipment Manufacturers) such as Sigma lenses will fit your camera body. Canon have a good reputation for their auto-focus, while Nikon make lenses that are the envy of others.
If this is your first digital SLR then you might be best buying an entry level body with a multi-purpose zoom lens such as the Nikon D40. There is a lot to learn.
If you are converting from film SLR and already have a set of lenses, then the cameras you mentioned will probably be able to use your existing lenses (but this is less so with Canon than Nikon). I was ecstatic to disover that my old Nikon 500mm mirror lens works in manual mode (with metering displayed) on my Nikon D200 but would not work properly on my Nikon D70.
I hope this helps.
Jan 01, 2009 | Nikon D200 Digital Camera with 18-200mm...
Damaged control panel d200
Won't be under warranty for accidental damage anyway.
Dec 07, 2017 | Cameras
Nikon SB600 flash behaving strangely
I have sent my SB-600 to Nikon twice in the past 6 months to resolve this problem. They have fixed it both times, but never told me what the problem was. I've had it back for exactly 1 day now, and it's started back up again already. If I receive a solution (or replacement), I'll let you know!
Nov 13, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon D200 Digital Camera with 18-200mm Lens Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
