Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore 44722 Portable Washer - Intermittent Aggitation Issue
Occasionally my washer does not aggitate properly while washing the clothes. The motor continues to run normally but it almost sounds like the transmission is trying to aggitate by "quick pulsing" rather than "wig-wagging"... After it completes the wash cycle like this, it usually works properly again the next time I use it. Any ideas?? Thanks.
IFIXALL
  • 868 Answers
SOURCE: aggitation problems
Replace the motor.
Posted on May 20, 2008
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
  • 1937 Answers
SOURCE: washer will fill, skips aggitation
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20832990
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
Posted on Nov 02, 2009
  • 1937 Answers
SOURCE: I need permanent hook up adaptor for
See the Sears Manual site for your washer.
They list a part number for converting from portable to permanent installation.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0411083.pdf
It's listed as part number 3935674.
Posted on Jan 20, 2010
  • 1937 Answers
SOURCE: i need to get the hose adapter for my portable
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
You may be able to find a hose adapter on the site.
Also check the Sears site:
for PDF manuals and you may find a suggestion in one of them.
Posted on Apr 01, 2010
Water coming from bottom white round piece of washer during aggitation
Could you please describe the problem you are having a little better?
Nov 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
Just purchased used a Kenmore stacked washer/dryer: tub spins during aggitation cycle. So my clothes are spinning around in water but not being aggitated. Now Im aggitated!! Grr!! How much will it cost...
Sounds like the plastic spacer between the transmission and the tub has broke. Part is no more than 5-10 bucks. Labor, not sure. Did you buy the warranty....I think you still have time to buy it if it's new... But I think Kenmore may guarantee for 30 days but you may want to call where you bought it from new.
Dec 14, 2017 | Kenmore Washing Machines
Model # 44722 Portable Washer Are you suppose to open washer to balance load while washer is in spin? I did and the tub stopped abrutly moveing the machine about 1 foot across the floor.
a safety mecanisim built into washers is the top lid switch it detects when the lid has been opened if you do this whilst its spinning it will engage a powerful brake as you saw to stop the barrel so you dont reach in and loose an arm its perfectly normal. if the washer goes unbalanced wait turn the power off at the wall wait till it stops spinning then re arrange the cloths
best of luck
please take the time to rank this advice
merry christmas
Dec 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
207 people viewed this question
Sal De
fordexpert
Robert Rankin
