Hi,I have a indesit w133 washing machine and up to now has been fine,however a problem has occured in that it does not move on from the wash cycle and does not heat up. Any advice much appreciated.
Try Vigrx ***** Enlarger Pills, yes we know who u are !!!!!!!
Posted on Jun 05, 2008
Indesit W123 drum not moving. Will turn freely and quietly both directions if spun by hand. Sounds like going through cycle and dial turns as is going through programme. Made a whirring noise when ini
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Indesit wg1185w wont wash
Hi, I think you will find that the heating cycle has failed! Does the water heat up? If not check the heater and the thermostat if you have one. No heat No wash cycle..!
Get back to me......
Jan 02, 2009 | Indesit WA 115 Front Load Washer
Indesit Prestige Line 822
i have this! 4 is a normal wash cycle 7 is a spin 5 an 6 seem to be quick washes an never tried 1 2 or 3!!! hope this helps!!
Jul 20, 2008 | Washing Machines
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
