Question about Sony Cyber-Shot DSC-S40 Digital Camera
Turns on for different amounts of time, if at all
Whenever I turn on the camera, it'll either A) Stay on for about 5 seconds. or B) Not turn on at all. On the odd occasion it actually DOES turn on all the way, when I go to take a picture, it turns off. I have new batteries in it, too.
  • Anonymous Apr 20, 2008
    I am having the same problem with my Cybershot. I have put in new batteries three times today, recharged the rechargable batteries, and still cannot get the camera to turn on.
  • sianlee Apr 20, 2008
    Same problem. At first I thought I just had low batteries, but it kept
    doing the same thing with new batteries. The real problem is it
    wouldn't stay on long enough to get the lenses to retract and close,
    but finally I got it to stay on long enough to close the lenses and
    upload my photos to my computer. When I turn it on, it flashes the low
    battery warning but I know the batteries are good.
    I also had the same problem where it would sometimes stay on, then shut
    off as I was focusing or about to take a picture. Frustrating!
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
When making a call, the inside display turns off
You have to go to your phone settings in your phone settings menu, and set your display screen to the amount of seconds or minutes you want the background to stay lit for, usually 15 seconds to 5 minutes..
Apr 06, 2010 | Motorola Mobility MOTO W755 Cellular Phone
After 30 or so seconds the camera turns off. it
You probably have it set on a power saving setting that powers down after a set amount of time. Go into the menu and check this out.
Oct 24, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
RCA CC311 camcorder it turns off after a few seconds
If your are still looking for an answer... The camera has some bad capacitors on one, or more, of the internal boards. I had the same problem.
There's a man named Cameron in Florida that can fix it (AV Repair), but it won't be cheap! I had him fix mine... it cost $350.00! But I love my camera... filmed many, many, things with it. It works great, and looks professional, and is... recorded tapes have excellent quality, and when transfered to DVD they can be enhanced (if you need to)!
Jun 19, 2009 | Quasar VM-L450 Camcorder
Camera will pan to an area but will not stay there.
Most PTZ cameras have an "inactivity" setting. If no command inputs are entered into the keypad for a programmed amount of time, typically between 30 seconds - 5 minutes, the camera will return to it's pre-set position. You should be able to turn this off in the camera programming. A good way to test to see if this is the problem would be to point the camera to an area, then make very tiny adjustments to the direction every 2-3 seconds. If the camera does not go to the pre-set, then inactivity is turned on. Also, point the camera to an area and time how long before it returns to pre-set. If it is the same amount of time on every occasion, this would also indicate that inactivity is turned on.
Let me know if this does not work, or if you don't know how to access the programming menu - steven.burman@commandtechnologyassociates.com
Nov 18, 2008 | Pelco ES3012 5MLZ30PW Esprit High Res...
Batteries problem....
Try rechargable NiMH batteries. They are specifically designed for today's technology, and last much, much longer than traditional batteries. It doesn't matter about the brand -- Energizer, Rayovac, Duracell, generic -- I've found that they all tend to last about the same amount of time in my digital camera. But I only use rechargable ones anymore.
Nov 14, 2008 | Concord Camera Eye-Q 4060AF Digital Camera
DMC-FZ20 won't stay on after power up
In the camera setup menu there is an option which says power saver......increase the time frame in power saver...it will solve the problem
May 30, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Lens wont go back in, camera wont stay on
I have the same problem.This problem comes back so many times on this site, there is no solution anywhere.... Pretty mad for a problem hapening many times.
Jan 09, 2008 | Cameras
Camera won't stay on
That has happened to me before. When I got my camera for the first time, I took all kinds of pictures. About a week later, it did the same thing yours did. So I got new batteries and I wouldn't work. So I went to the store where I bought it and had it exchanged for a new one. If you haven't scrached it or anything and kept the reciept, then go to where you bought it and have it exchanged.
Aug 18, 2007 | Samsung Digimax S630 Digital Camera
Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
