Question about Dryers
Clothes Dryer Start Switch
I need the start switch for the GE clothes dryer model dde5100ralwh
    Genius:
  • 1,073 Answers
Part number is we4x782
Posted on Apr 12, 2008
Pushed start switch and making huming noise and won't start ge gas clothes dryer model dvlr223gg8ww
In most cases the motor is seized or something is preventing it from spinning (seized drum wheel for example).
Feb 10, 2015 | GE Dryers
Dde5100ralwh
open the door and check the door switch,push it in and out,it should click when you push it in,if the door switch is broke it won't start,also if the dryer has been taking longer to dry the clothes and hasn't been taken apart and cleaned out either the thermal fuse or one of the thermostats could have blown,all a dryer does is move air,if lint blocks up the vent line or in the dryer duct where the lint filtr slides into the dryer runs hot and one of the fuses or thermostats will pop as a safety.if you live in mass. peter de's is a good appliance corp. to call,781-438-9442
Jan 13, 2014 | Dryers
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
GE d clothes dryer starts when you close the door, before you turn the saitch.
Dear Dan,
You may have a bad start switch. Here is how I would check it.
Unplug your dryer, and remove the back of the control panel, which usually means pull it out from the wall and take out about 6 or 8 screws. There is usually a long rectangular panel for the control panel access.
Locate the start switch and unhook the wires from it, being certain that the wires are then not touching anything at all.
Then plug in the dryer and see if that is what the problem was, it should not turn on at all.
You can buy new switches from an appliance dealer, or from "Sears Parts" on the internet.
You can buy new and used switches from e-bay.
Be blessed.
Oct 31, 2011 | GE WE4X881 Clothes Dryer Start Switch
Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 01, 2010 | GE DWSR405EBWW Electric Dryer
The dryer starts without using the start knob when you open and close the dryer door during a cycle. The dial is also not advancing during the dry cycle and the clothes are taking a long time to dry.
Assuming that you have GE dryer DBXR463ED0WW,
Sounds like there is a couple of problems there:
  1. The start switch is stuck and needs replacement/repair, part number WE4X881
  2. The clothes taking too long to dry may be due to a) clogged dryer vent; b) one or both heater coils burnt out; part numbers: WE11X10007 for restring coils only or WE11M23 for whole heater assembly c) problem with temperature selector switch, part number WE4M407
  3. There might be a problem with timer (WE4M271), but before replacing it I'd suggest taking care of the long dry problem first. In some models, timers are wired that way so the timer advances only when there is heat, so check the schematic.
There should be a schematic diagram inside the control panel, use it to for diagnosing the problems you described.
Good luck,
Vlad
First Choice Appliance
Apr 10, 2010 | GE DBXR463EDWW Electric Dryer
Buzzing noise when i turn the timer switch
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Dryers Logo
187 people viewed this question
Top Dryers Experts
