Question about Canon Elura 65 Mini DV Digital Camcorder
Moving photos from pc to Elura 65 camcorder memory card
Is there a device to plug into my usb port that will allow me to move photos from my pc to my memory card? I want to use the card in a digital frame, but my Canon Elura camera isn't recognized as a drive by my PC and the camera software allows camera-to-pc transfer only. Thanks.
  • NonieB Apr 12, 2008
    Mark Webber, you are awesome. Thanks!!! NonieB
  • 472 Answers
You can buy both internal and external USB card readers that can read just about any card you can think of in a package about 3" square. They are not expensive either.
Your local PC retailer will (read should) have these in stock.
Hope that helps
Posted on Apr 12, 2008
Kodak no longer spports or provides Easyshare software and I need my PC to see my Easyshare z700
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Mar 03, 2013 | Kodak EasyShare Cameras
How do I download pictures from a AT&T Z221 to my PC using a USB cord?
Plug the USB cord from the camera into the USB port on your computer. The computer should see the camera as an external storage device. You can then click on the storage device and open the folder and copy the photos to your computer.
Feb 19, 2013 | Cameras
Moving photos from Samsung S11 to computer
Jan 17, 2013 | Cameras
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
What cable is required to download the recorded video on tape?
To download from the tape (not the memory card) you need a firewire cable, and a computer that has firewire compatibility. Most laptops have this, but desktops may require a firewire card to be installed.
May 05, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Nov 12, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Camera not detected by XP
Are there any settings in the camera's menu to tell it to switch to PC Mode?
Mar 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon Elura 65 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
