Question about Tascam Audio Players & Recorders
I just bought a Tascam Portastudio 424 mk III (not 2)). It is supposed to be in "like new, perfect" condition and it looks fine. But when I try to play a tape the music comes out backwards. I did shut off tracks 3 & 4 per the manual (page 9) but I still hear everything backwards. I don't think the machine is broken, I just don't know what I'm doing and the manual isn't much help. What am I doing wrong? Thank you.
ice man
  • 68 Answers
SOURCE: tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Posted on Apr 15, 2007
  • 79 Answers
SOURCE: Tape deck turns on, operation sounds & looks NORMAL- yet won't function
Belts are prone to harden over time, like 10 years. The belt probably broke.
If you don't feel comfortable removing the housing yourself, take it to a repair shop.
Posted on Mar 21, 2008
  • 189 Answers
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
Posted on Apr 25, 2008
robotek
  • 1512 Answers
SOURCE: Tascam 424 MKII - ate a tape and buttons dont' work. Heads seemed locked.
Hi rob
The machine has idler assemblies that provide drive to the "takeup reelbase" When this drive fails, the tape is not gathered up into the cassette, but rather wraps around on itself on the capstan spindle and pinch roller. The mechanism will not release until the tape has been extracted from about the capstan spindle. This can require all sorts of ingenuity to acheive with pout damaging or bending transport parts. The tape may not be recoverable. The deck will require an overhaul to the transport belt and idler drives to get it back to decent working order again. If you could get it to me, cost you about $75 to overhaul it If you are not in Brisbane Australia, then you may have to locate someone near to you.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
SOURCE: play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Posted on Apr 15, 2009
Tascam 424 mk 11 wont record but lights come on
These unit as small as they are have to be worked on by professionals that know how to fix them. So far as I know there is only me in Chicago and Russ in New Jersey that can repair them.
Without seeing the unit I can not tell you more about how to fix it.
It could be anything in the unit that has the problem.
Jul 27, 2016 | Tascam Audio Players & Recorders
I have a tascam 488 mk II when its turned on the play record and pause lights all are blinking and dont know why?
check to see if any of the buttons on the play/record panel are pushed down or stuck if not go to the tascam website and submit a trouble iinquiry
Oct 08, 2014 | Tascam 488 MKII Portastudio
Tascam 122 mk III error code
The Tascan 122 Mk III does not have a computer in it to give error codes. I suspect that you have a power supply issue but I can only help you if I see the unit. I am in the Chicago area and run a shop for fixing these decks. I have been doing it for 40 years and have worked at the Teac Factory Service in IL.
skywavebe@sbcglobal.net if you need my help.
The symptoms are recognized as a cracked transport gear that is resolved by a new gear and a transport cleaning and new grease put in. I have done about 6 of them as this is described. I have parts in stock.
Sep 06, 2012 | Tascam 122MKIII Single Dual Cassette Deck
I need a power supply for a tascam 424 mk iii. It
Check these out: http://www.audio-depot.com/index.php?main_page=product_info&products_id=1571&currency=USD
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350275805259&rvr_id=&crlp=1_263602_263622&UA=M*S%3F&GUID=c3a1fd4411e0a0b586e289a2fff2035d&itemid=350275805259&ff4=263602_263622#ht_600wt_941
Oct 10, 2009 | Tascam PS-PS5 Power Supply Power Supply
Tascam 424 MK II, how to bounce tracks?
Here is a link I found that took me to an owners manual for your device.
http://www.scribd.com/doc/264105/TASCAM-424-mkII-Manual
Hope this helps :D
Jun 06, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 424 portastudio mkII power supply
My mistake this is a 424 mkIII not a mkII. Sorry for the typo. Great news is I opened the power supply case and un-soldered the fuse. cleaned it off with tarn-x and behold 3 amps 250 volts. Definatly worth the $1.00 im gonna have to pay for that. As for the **** that was gonna charge me a $100 bucks. There is a reason you are doing that to people. And one day your services will be obsolete.
Apr 28, 2009 | Tascam PS-PS5 Power Supply Power Supply
TASCAM 2448 xp drivers
I have a tascam 2488mk11 whit no driver cd also .Tascam is pulling a scam
Jul 30, 2008 | Tascam 2488 Portastudio Multitrack...
Okay I have found two solutions here. They may both be the same but the information here is kind of vague so I will post them both. I have found a PS-PS5 power supply as the title suggests. It can be found here: http://www.supermediastore.com/tascam-ps-ps5-power-supply-for-trainer-series.html I have also found a power supply for the Tascam 424 mkii which can be found here: http://cgi.ebay.com/Tascam-PSP424-Replacement-Power-Supply_W0QQitemZ7405614833QQcmdZViewItem Hope this helps!
Jun 10, 2007 | Tascam PS-PS5 Power Supply Power Supply
93 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
