Question about Creative Labs ZEN Vision:M Digital Media Player
ZEN NOT CHARGING
Hi Guys,
My zen appears to be frozen, the screen is blank and will not take a charge from my PC. When plugged into the PC, the blue power light on the top of the zen flashes continuously. Can you help?
  • 4 more comments
  • Crake Apr 13, 2008
    When i connect my wall power source it turn on, but appears the green icon on the screen which represents that it's full charged. That's not true, because since i unplugged it, it automatically turns off. With the usb cable it just blinks the blue light on the top of the unit, nothing else happens.
  • iacchos777 Apr 15, 2008
    I also have this problem and don't udnerstand what to do. I've tried to hit the reset button witha pin at the bottom but, nothing seems to work. It's just that stupid little blue light! lol! :-( Anyhow, I am just past my warranty so I can't even get help from Creative.
    I hope someone figures out what the answer is and how to fix this.
  • Anonymous Jun 16, 2008
    yes
  • ZenBad Jun 19, 2008
    Sounds like my problem too. One day it worked fine, the next day the screen would not come on. I could still hear music and the buttons would operate, but I could not navigate without seeing the menus. Then when the battery went down, nothing happens. When I plug it into my PC the blue light flashes, but the PC does not even recognize the Zen like it should. Reset button doesn't do anything, and it doesn't seem to take a charge. It happened exactly 2 weeks after the 1-year warranty expired. Is this pre-programmed?
    Anyone have any answers?
  • ckwashuk Jun 27, 2008
    Creative Zen Micro not charging...purchased new battery and it worked again, until the battery drained now I am singing to myself again, and let me tell you its not pretty, please help.
  • psuanimal May 11, 2010
    ellobobill
    was correct, this worked for me! problem solved! thanks alot...
  • 3 Answers
Here, this is what I did to fix this problem. copy and paste from my original post on anythingbutipod.com
"My player is completely charged, I have XP w/SP2 - I can turn it on and listen to the default audio tracks and videos...I just can't get my computer to recognize it AT ALL!"
and then:
also, when I try to allow "everyone" to the USB....I found that in the advanced section I have TWO "everyones".
The one that says "full control" says "not inherited" in the inherited from column...the other says "read" and "machine\system\currentcontrolset......."
Should there be two of them in there??? Because when I try and switch the read to full control, it reverts back as soon as I select apply or ok....I tried deleting it but it re-creates itself soon as I go out of the window.
so I was told to do this:
Sounds like an NT problem. I don't know the exact steps to do this, but you'll need to remove inheritable permissions from that, which will remove the "inherited" attribute, leaving the locally-controllable one.
So open "run" command in the start menu and type "regedit"
From there follow this path...
"hkey_current_config" -> system -> current control set -> Enum -> USB
Do what I copy and pasted above and then plug your Zen V:M in and it should recognize it.
Posted on Jun 21, 2008
I cannot get my zen to take a charge and if it does the battery saying full is only holding about 2 minutes, and this is a replacement battery
Posted on Nov 01, 2010
I also have this same problem. Just started happening today. NEED HELP PLEASE!!!!
Posted on Apr 15, 2008
Hi, my ZEN vision m: does not start anymore; when charging the blue light just "flickers", but even after 1 night charging, no possibility to get to the menu
The rapid-blinking blue light means that the Zen's battery is too drained to allow the player to turn on.
It can take 24 hours or more to completely recharge the Zen using USB. If you see the blue light blinking slowly when you plug it in, then the player is charging, and you will have to wait for it to finish charging.
If, after leaving the Zen to charge for more than a day, it still does not turn on, then the battery may be defective and not able to be charged anymore. The battery will have to be replaced.
May 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
My mp3 player stays on all the time and i cant turn it off
  1. Check that the Creative Zen Touch has the most current version of the firmware driver. Firmware updates typically fix most common errors and problems encountered when using the Zen Touch. Turn on the MP3 player and select "System" in the home menu. Click "Information" then press "Settings." Select "About." Look for the internal firmware's version number listed under "Version." The most recent firmware is 2.01.00 and was released in 2006. If your software is outdated, download an update from the Creative support site: http://support.creative.com/downloads/download.aspx?nDownloadId=100120
  2. Ensure that the song files you are trying to transfer to the Zen Touch are compatible with the player. On your computer, right click the song file to view its file format. The Zen Touch can play all unprotected WMAs, WAVs and MP3s. It does not support the popular protected AAC format that is used in online stores such as Apple iTunes.
  3. Verify that the Zen Touch's internal battery is fully charged. This may cause what appears to be a blank or dead screen, as well as slow responsiveness to your touch. Insert the power adapter brick connector into the Zen Touch's power port found on its right-hand top corner. Plug the adapter into a wall outlet to begin charging. The MP3 player will be finished charging in four hours. You may use the MP3 player while it is charging, but this may slow down the charging process.
  4. Adjust the screen contrast on the Zen Touch. This may resolve any issues you have with viewing the screen in bad lighting. From the main menu, click "Settings" and choose "Contrast." Slide your finger up or down the Zen Touch's touch pad to adjust the contrast to a suitable setting.
Sep 24, 2009 | Creative Labs Zen Touch MP3 Player
CREATIVE ZEN MOZAIC WON'T TURN ON!!!!!
i just reset mine as mine would not turn on, i held it for a few seconds ant then turned it on and it came on! but mine is chargint at the moment, but the flashing light is red! i thought it was supposed to be green??? Can anyone help?
Sep 03, 2009 | Creative Labs Creative Technology Zen MP3...
I did not use my Zen MP3 4GB player for several months. On attempting to re-start it, I was unable to get anything except a blank -although lit - display screen. The player has been charged for many hours,...
try to drain the charge of the battery. the try to recharge it. most white screen issue of creative zen is due to power surge specially when it's connected to a usb port.
Aug 16, 2009 | Creative Labs Zen V MP3 Player
Blue light is on but zen wont turn on or off
on the top right of ur zen get something sharp and poke the reset button see if that works
Feb 06, 2009 | Creative Labs Zen Digital Media Player
Zen mosaic frozen on charging screen
Try hitting the reset button. Its the small one on the left side. You might have to push it with a pen or something,
Jan 28, 2009 | Creative Labs Creative Technology Zen MP3...
Creative Zen Vision M - Dead Machine
unfortunately,the best solution is to send it back to creative for them to check it out. this sometimes happens when the player has been unused for too long and battery "under charges", which there is a solution.but seeing as u used it under normal conditions,that cant be the problem
Jun 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Won't turn on.
I had exactly the same problem as Damma32.
This solved the problem:
I plugged the ZEN out from the PC and pressed the reset-button, then pressed the play-button while turning it on again. when the creative logo appeared on the screen I released the play-button and a recovery-meny appeared. I used the clean-mode, which fixed the problem.
May 11, 2008 | Creative Labs Zen Digital Media Player
Frozen
I have the 8gb Zen and I usually end up with a frozen screen when I upload music. I unplugged the Zen and then use a needle to reset the player. It located at the bottom right.
Mar 29, 2008 | Creative Labs Zen Digital Media Player
ZEN MP3 ( frozen)
If it has frozen Chances are it'll do it again so i suggest you take out your warranty and exchange it
Jan 15, 2008 | Creative Labs Zen Digital Media Player
Creative Labs ZEN Vision:M Digital Media Player Logo
953 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
