Question about Epson Stylus Photo R1800 InkJet Printer
Stella Mac Aperture Print Print setting is not possible
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 11, 2010
    Which driver version are you using? and What os version? intel core duo or ppc mac? can you access print settings on other application except aperture?
    Genius:
  • 1,447 Answers
Check on adobe website for forums regarding the problem, try printing frm other application as well. if its not printing from aperture only then there is a problem on the program.
check this site:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=332627
Posted on Apr 17, 2008
Does Stella Hudgens have a website for her fans?
http://www.fanpop.com/clubs/stella-hudgens
Jul 20, 2017 | Sewing Machines
I have a tamron 28-200mm lens that have a aperture ring at the back .. so is it possible to lock the aperture at f3.8 and shoot at 200mm focal ?? (this lens was f3.8- f5.6) by the way i was using a n
If you're using a Nikon camera, you want to lock the aperture ring at its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
This has nothing to do with the focal length. You can shoot at any focal length from 28mm to 200mm.
Feb 10, 2014 | Cameras
I have a Nikon D70, and a Quantaray lens (28-90mm). I have had this camera for about four months, and it has been working fine with the lens. When I received the camera, the aperture ring moved, but the...
In order for the aperture to be controlled by the camera's program or primary and secondary control knobs, the lens must be set to the smallest opening - or highest number value f stop. The aperture must be operated by the ring if it is not left in the smallest opening position.
The FEE code you are seeing refers to a communication error between the lens and the camera body. Sometimes, simply removing the lens from the body and reseating it to the body will solve the problem. While the lens is off the body, carefully inspect the gold colored contacts on the lens and mating contacts on the camera body. Remove any dirt or debris found, being careful not to allow it to fall into the camera - or land on the back glass of the lens.
I found another explanation and possible remedy that stated:
"A flashing "FEE" is an improperly set aperture ring in 99.9% of all cases with this error message (i.e. user error). In very rare circumstances it can be caused by a damaged aperture ring (small lug broken from back edge) that can't "tell" the camera it is at the minimum position. If the aperture rings on the lens is set to minimum aperture (highest number) and locked there, but you still get a FEE error, it's possible that sloppy tolerances are causing the lens aperture ring to not move the little switch at the 8 o'clock position (on the D70 lens mount) as far as necessary to get a proper indication of minimum aperture. Try to see if the aperture ring (while locked) will move slightly when mounted on the camera to clear the FEE error.
Another remote possibility is that the little switch at the 8 o'clock position mentioned above is not functioning properly (sometimes they get dirty). Try "exercising" it by moving it back and forth with your finger, then try the lenses again. Usually FEE has nothing at all to do with CPU contacts (with a reverse engineered third party lens anything is possible I suppose), but it doesn't hurt to clean them to eliminate that possibility."
You can also try a different Nikon compatible lens. If the trouble is still present, the camera may need to be returned for repair. If the the problem goes away, then the issue is tied to the lens itself. This would mean the the lens needs repair.
I hope this helps and good luck! Please rate my reply - thanks!
Jun 30, 2011 | Quantaray 28-90mm f/3.5-5.6 for Pentax
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Getting Error FEE when in manual mode
The error code means that you have mounted a lens with a manual aperture control and have failed to set the control to the minimum aperture setting (highest number). By setting the control to the minimum aperture, the camera can then automatically select any aperture between the maximum and minimum settings when taking the photo. The actual aperture selection is either set automatically by the camera body (if in shutter priority or auto/program modes) or is done using the camera body controls when in aperture priority or manual modes.
If you have done so and still have the problem then add a comment and we'll explore further possibilities which all involve a fault with either the lens or the camera body.
If I have resolved your problem then please take a moment to rate my answer.
Apr 19, 2010 | Nikon N65 35mm SLR Camera
Nikon D40X In Program mode (P*) I can not change settings. Nikon's video show it is possible to do this using the command dial. Any suggestions ?
Program: Puts the camera in charge of aperture and shutter speed, though all remaining camera settings are available. You can vary the combination of aperture and shutter speed the camera has selected by rotating the Command Dial.
from: http://www.imaging-resource.com/PRODS/D40X/D40XMENUS.HTM
The camera takes care of the shutter and aperture settings, and you control the other stuff...(presumably white balance, focus points...etc.?). I hav ea D70 and using the thumb wheel, I can, on 'P' mode, set the aperture...but the shutter speed is always 'auto' as far as I can tell.
Best of luck!
Nick Chapman http://ChapmanIT.com
Jan 05, 2010 | Nikon D40x Digital Camera
Error message shows F -- with lens attached. Lens was cleaned with compressed air, now willnot work. Lens type Nikon 28-80 AF
Check to see that the lens aperture ring is set to the smallest (largest numerical) aperture setting (usually f22 or such). Nikon AF cameras have to have their lenses set at the smallest aperture for most of their program modes to work. Nikon AF lenses have a small slide or twist lock adjacent to the aperture ring to lock it in place at the smallest aperture. This may have been unlocked during the cleaning.
Another possibility is that the lens's electrical contacts were damaged during cleaning, so the body is not "seeing" the lens. Do you have another lens you could attach to the body to test this theory?
Aug 06, 2009 | Nikon N50 35mm SLR Camera
Photo software
Depends on what you want to do.  For general photo storage, organization and amateur editing, I LOVE Graphic Converter.  You could also 'dance with the one who brought ya' and use iPhoto.
Jul 22, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Aperture
On digital cameras you set the camera to Aperture priority and then use your spin dial to set the lowest aperture possible and let the camera set the shutter speed.
In basic terms, the lower the aperture number the shorter depth of the vision field that will be in focus. This is called Depth of Field.
If your camera doesn't have an Aperture priority, usually a capital A on the program dial, you are a bit out of luck... that said, almost all cameras today have this feature. Yours may also be accessed by setting the program dial to Closeup or Portrait mode where the camera will use a short Depth of Field to blur out the background.
Hope that helped of fixed your dilemma.
Worldvet
May 21, 2008 | Casio Exilim EXZ75 Digital Camera
Driver for Dell A940 printer for my new Mac lap top
There is no mac driver for the Dell A940. What you could possibly do is, if you have a network, connect the printer to a windows PC, set it up as a print server and then connect to the print server from your mac.
Jan 05, 2008 | Dell A940 All-In-One InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
